Old 09-26-2014, 04:09 AM   #1
Stayreal
Drives: 13' Scion FR-S
Questions about Valve Stem Fitments
I've been trying to search around for it but couldn't find the answer.
So, basically has anyone tried RPF1 Valve stems with the OEM TPMS? Does it fit? or new OEM valve stems is only choice to work with OEM TPMS? Did anyone tried other aftermarket brand valve stem fit?
Stayreal is offline   Reply With Quote
Old 09-26-2014, 09:40 AM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
The TPMS has it's own valve stem. You can't use an aftermarket stem for it, since the sensor bolts into the stem.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-26-2014, 11:18 AM   #3
wparsons
wparsons's Avatar
^^ 100% correct.
flickr
Old 09-26-2014, 11:28 AM   #4
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I bought an adapter to put stock TPMS sensors on WORK wheels.
Jyn is offline   Reply With Quote
Old 09-26-2014, 01:50 PM   #5
wparsons
wparsons's Avatar
He's asking about using different valve stems with the stock TPMS sensors, not about using the TPMS sensors in different wheels.
flickr
Old 09-26-2014, 04:25 PM   #6
Jyn
Noob
Jyn's Avatar
AH. Thanks for clarifying, I completely misread that lol
Works Valve Stem & RS-R Lug Nuts xDBOYx Wheels and Tires 7 11-29-2014 05:23 PM
Are your valve stem caps safe? qqzj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 10-18-2013 01:32 AM
Question about wheel fitments wilfredwong Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-14-2013 10:53 AM
DIY Antenna Stem Removal ninjasaurusrex DIY (Do-It-Yourself) Guides 18 01-29-2013 10:35 PM
Can this valve stem be rebuilt? ayau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 12-24-2012 02:57 AM
