Old 01-15-2019, 03:15 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Clunking coming from bottom of car after hitting enough bumps
The roads are bad here, so I try my best to drive with caution. Unfortunately I go over bumps sometimes and yesterday must have been the one that did damage. I have aftermarket coilovers - cars not super low but it takes a beating. So I go over a bump and now I get a clunking or like, knocking vibration under the car near the feet when I drive over even the slightest of bumps. My first thought was that maybe since it's a cold winter something snapped from the impact or a bolt came off, I checked under the car, nothing out of the ordinary. Pulled both front wheels off and checked. I found 2 things, the passenger side I noticed something that doesn't look right. I'm not an expert but you guys are so knowledgeable so please help me out here. You'll notice the metal box is split open.. not sure if it's always been like that:
https://imgur.com/a/lvJjZeZ
And a little closer:
https://imgur.com/a/Mi0GKgx
Last thing is the driver side coilover's weather guard is ripped in half, is that a massive red light? I won't drive the car until it gets looked at but just wanted to get your guys' take. Thanks in advance!
scottryan is offline   Reply With Quote
Old 01-17-2019, 07:05 PM   #2
humfrz
I suggest you take it into a reputable auto shop and have then inspect the suspension and fix anything that's wrong.
Thar ya go -
humfrz
Old 01-18-2019, 10:51 AM   #3
scottryan
Financial Distress
scottryan's Avatar
Thar ya go -
humfrz
Getting it done this weekend, thank you!
Old 01-18-2019, 01:19 PM   #4
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
While the wheels are off, check your "Bump stops'. They're basically bushings for your shocks, they're very cheap to procure and they're designed to be a buffer between the metal between suspension and frame.
If you've ever had a back injury, think of the bump stop like the 'disks' in your spine. They keep the hard parts from smashing into each other.
slizoth is offline   Reply With Quote
Old 01-18-2019, 02:30 PM   #5
humfrz
Well, SHIT - NOW you tell me -
I just had a long and expensive spine surgery and all I really needed to do was go up to the automotive shop - thanks a lot! -
humfrz
Clunking noise coming from the back ft_86 Issues | Warranty | Recalls / TSB 6 03-03-2016 11:30 PM
Clunking sound coming from suspension Maverickgear Issues | Warranty | Recalls / TSB 9 07-11-2014 02:41 PM
Clunking noise when on and off throttle and bumps DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-23-2014 11:18 PM
speed bumps jmaryt Scion FR-S / Toyota 86 GT86 General Forum 25 03-05-2014 10:34 AM
Wheel hitting tie rod? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-16-2013 05:17 AM
