Old 07-15-2013, 09:31 PM   #1
OakmanSmalls
Drives: 2013 DGM BRZ
Wheel hitting tie rod?
Someone brought up that my new wheels may hit the tie rod at full lock. Wondering if anyone can verify before I pick these up and the don't function.
17x9 +44 running stock 215 tire
Car is 1.2 inches lower all around.
Thanks
OakmanSmalls is offline   Reply With Quote
Old 07-15-2013, 09:39 PM   #2
djdnz
1337
Drives: 2013 BRZ WRB S/C
They will likely rub at full lock. We know for sure that the 17x9+45 enkei RPF1 hits the tie rod at full lock. I doubt 1mm is going to make enough of a difference. You might get away with it with a 3mm spacer, or deal with the minor rub.
Please get a wider tire.
djdnz is offline   Reply With Quote
Old 07-15-2013, 09:44 PM   #3
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Why do I feel that polite remark had just a small hint of disdain for a highly stretched tire ....
TrogDor the Burninator is offline   Reply With Quote
Old 07-15-2013, 11:10 PM   #4
OakmanSmalls
Lol I agree. Just budget conscious right now. I'm not about the stretched stance shit either. Maybe I'll reconsider my size options. I want the wheel close to the fender but want full functionality. Know any good fitments off hand?
Old 07-15-2013, 11:18 PM   #5
GoSharks
GoSharks's Avatar
Drives: BRZ Limited, WRB, 6 MT
I am looking at 17x8 in RFP1 instead of 17x9 myself
GoSharks is offline   Reply With Quote
Old 07-16-2013, 12:56 AM   #6
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
i can confirm this but will say that it hasn't been an issue. however when i went 245/40 on 17x9 et45 rpf1 the tires hit the oem lower spring perch too. ymmv depending on the tire brand as well.
garfull is offline   Reply With Quote
Old 07-16-2013, 05:17 AM   #7
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
it will depend on the actual design of the wheel as to whether it hits...
I have the +45 17x9 and brought up this tie rod rubbing issue.
It is very close either way.
with a new alignment and a slight toe in there is no rubbing under normal usage. it is only if your car is very low and or compressing the front suspension at full lock (this doesn't happen on the street) and pretty much not at the track unless you are messing around.
I was going to get 8s for the front but it hasn't scrubbed since the last alignment... mine is only ~25mm lowered. it is not an issue for me anymore...
86•BRZ is offline   Reply With Quote
Vortech Hitting The Streets - All FR-S Edition Brian@Vortech Forced Induction 35 05-23-2014 05:41 PM
Overpipe hitting frame/engine Kregar Engine, Exhaust, Transmission 26 05-18-2013 10:23 PM
BRZs hitting Tampa, FL! FLHC BRZ First-Gen (2012+) — General Topics 63 07-24-2012 10:20 PM
First newspaper reviews hitting the web.... Sport-Tech BRZ First-Gen (2012+) — General Topics 12 05-12-2012 09:32 AM
Video: Ken Gushi Avoids Hitting Deer While Filming FR-S Commercial Jayvelliott FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 48 02-10-2012 01:41 AM
