Old 07-09-2014, 04:10 PM   #1
Maverickgear
Drives: World Rally Blue BRZ
Unhappy Clunking sound coming from suspension
Hi guys,
i have recently found myself in quite a pickle. A few weeks after swapping to a coilover kit, a certain clunking noise started surfacing. At first I attributed it that it might be a bad endlink or something, but things were not that simple as it turns out.
The sound only occurs when turning and going over uneven terrain. I also have recently installed a Cusco LCA for camber adjustment, but I doubt that would be the root of the problem since the sound occurs in the front as well. I am hoping someone with a little experience on this would chime in on this issue.
I have brought it back to the dealer who sold me the coilover kit and they've been really kind to follow me through to try and solve this issue however they could not pinpoint the problem as well.
Here's a video of the sound, to better describe the situation.
[ame]http://youtu.be/LaC6-sojxn4[/ame]
Any help or suggestion would be deeply appreciated.
Thanks
Maverickgear is offline   Reply With Quote
Old 07-10-2014, 12:54 AM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Pop the bonnet open, and have someone turn the steering wheel from lock-to-lock, whilst you listen for any sounds coming from the front suspension. If you can replicate the sound this way while stationary, chances are your top nut was not torqued correctly.
Fizz is offline   Reply With Quote
Old 07-10-2014, 03:52 AM   #3
Fastbrew
Drives: 2014 Pearl White BRZ
Sounds like a submarine! Which means metal on metal somewhere.
These things can help sometimes...
http://www.tein.com/products/silencer_rubber.html
Good luck!
Fastbrew is offline   Reply With Quote
Old 07-10-2014, 04:30 AM   #4
tjohnson104
Drives: brz
this is the exact same thing my car sounds like. for a week every little bump I had a very loud and annoying metal clinging and clanking noise. Sounded like a rock got shoved up in one of the under panels, so I made a left turn and something fell out and then my noise was gone. In defense, I do believe it was a rock because it rained heavy and I drove over a washed pile of dirt and rocks after the rain. and I never had that problem before that. But now every time I turn left, there is a thump thug noise. Does not occur when at a stand still and I spin the wheel. Only when i drive and make left turns only... I have no idea what it could be. Only suspension mod I have is trd sway bars, and that was installed months ago and no issues until now.
tjohnson104 is offline   Reply With Quote
Old 07-10-2014, 05:28 AM   #5
Maverickgear
Good luck!
Yes indeed it does! Haha! What a way to put it.
Well, I've removed them and replaced with the stock set. The mechanic can't diagnose what's the issue either. Going to wait for a replacement set.
Old 07-10-2014, 07:57 AM   #6
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
are your tophats properly tightened?
TONYpepperon1 is offline   Reply With Quote
Old 07-10-2014, 03:50 PM   #7
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
spring spinning?
yeah check your top nut first if they were correctly bolted.
hanabie is offline   Reply With Quote
Old 07-10-2014, 05:37 PM   #8
tjohnson104
Drives: brz
what are the top hats? I pretty sure me and OP have same problem and I wanna check mine out too.
Old 07-10-2014, 09:07 PM   #9
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
After about 3000 miles on my coilovers a similar noise surfaced, I went in and tightened every suspension bolt up in the front of the car, even the subframe. Noise still persisted. For whatever reason was going on in my head at the time I greased up the rubber where the spring itself sits, and the bushing for the sway bar. Noise vanished. I live in a super dry climate and blame it on that. It has started to surface again, we've been having a lot of 100+ degree days so I'll get out a little grease and repeat.
Perhaps this can help your issue if you can't find any loose hardware
Ken
VacantSky is offline   Reply With Quote
Old 07-11-2014, 02:41 PM   #10
TONYpepperon1
Its the top nut which holds the spring and strut assembly together. The top hat is the actual top piece of the strut.
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 04:11 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
AST suspension coming G-Man Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 08-29-2013 01:11 AM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 09:50 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 06:16 PM
