Old 01-04-2019, 02:46 PM   #1
Flame9020
Drives: 2015 Scion FR-S
Winjet Foglight Install Help
I just finished wiring up the fog lights and when I went to turn on the car all I got was clicking. Im assuming when I tapped into one of the ingnition wires for the switch I created an issue. I used their plastic quick connect that they supplied and tapped the red wire from the switch into the lower right wire indicated in the picture. Can anyone assist? What can I do to get my car running again.
Thanks
Flame9020 is offline   Reply With Quote
Old 01-04-2019, 02:57 PM   #2
Flame9020
Edit: Just checked the battery terminals and they were only reading 11.5V. I hooked the battery up to a charger which read 13V when connected, tried to start the car, got one crank then nothing. Any thoughts?
Old 01-04-2019, 03:00 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Let it charge for a while and then try again
Old 01-04-2019, 03:04 PM   #4
Flame9020
Could there be a huge battery drain? Should it work after letting it charge what do you think the possibilities are that it will happen again?
Old 01-04-2019, 03:06 PM   #5
Flame9020
Also I noticed that the window didn't rise and the cabin light stayed on when I closed the door, so the car seems to think the door is still open. Is this also due to the lack of voltage?
Old 01-04-2019, 04:36 PM   #6
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Maybe during the fog light install you drained the battery too much. By having the doors open for a while and having the headlights on?
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 01-04-2019, 04:39 PM   #7
Flame9020
Car started after an hour or so of charging, fog lights did not turn on. I suspect there is an issue with how I wired the lights that might also be leading to a drain. Any ideas how I can track this down? Sorry for all the questions.
Old 01-04-2019, 06:06 PM   #8
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
I dont know how confident you are on that wire you tapped in to for being a good power source. Sounds like maybe you should undo that tap and hopefully it didnt create a break in the wire.
There is a factory connector in the harness for the OEM fog lights that can be used. that takes advantage of the existing wiring and relay. However, you lose the ability to turn the fogs on/off as desired regardless of headlight operation.
see this thread and my post at the end.
https://www.ft86club.com/forums/showthread.php?t=68691
The Following User Says Thank You to bmacfrs For This Useful Post:
kevaughan (04-11-2022)
Old 01-05-2019, 01:25 PM   #9
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Thanks for posting this. I've got a '13 FR-S and physically installed the Winjet foglight kit about two years ago.. but never wired it... too chicken to risk messing up factory wiring, and not enough experience to find the best place to access the needed ignition-switched power source for the dash switch. The winjet kit I have came with a fuse and relay to be mounted in the engine compartment and wired directly to the battery and chassis ground; the dash switch just triggers the relay. I don't recall seeing the connector inside the side dash panel you showed in your pic when installing my switch, but I'll look again. Since I'm using the Winjet-supplied relay and fuse, do I only need to tap into one of the wires in that connector for the switch (along w/ a ground connection, of course) and, if so, which one?
Thanks .. it'd be great to finally get this figured out and have my foglights work as intended.. automatically switch off when hibeams are activated or headlights are off, and only work when lobeams are on.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 01-05-2019, 04:23 PM   #10
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
So if you want the factory operation like you said, then you wont need the winjet harness (mostly), fuse, relay, or make any direct battery connections. The built-in factory wiring, fuse, and relay is already there. Using that connector shown in the pic is the way to accomplish that. I found it further up under the dash to the far left. Pretty much like the pic shows.
I did take advantage of the winjet harness for the fog lamp connectors and any wire needed. That OE instruction sheet is good for reference too.
http://www.trdsparks.com/install/PT413-18130inst.pdf
It shows how to use the parking lamp connectors to power the fog lights. So you will run wiring from those to the fog lamps and also for a ground. Then the switch needs installed and wired to the factory connector. I think I recall Winjet supplied a short harness with connector to the back of the switch. So i must have cut off the factory connector and spliced them together. I put color coding on the other posting as you saw.
Since you have the lamps already mounted you might be able to do that wiring without removing the bumper again.
EDIT: sorry I didnt really answer your actual question there... Assuming you are using the Winjet harness since its already installed and wired to the lamps. I found that factory connector had a white wire that seemed to be hot with ignition on. But I would suggest testing that and the operation of the lamps using that as a tap source.
The factory wiring and relay takes care of the fog lamp on/off operation with the headlamps. I dont recall how the Winjet install handled that, if it does at all. Hopefully their instruction info makes that clear.
Good Luck.
FRS Winjet Foglight red wire install klearfade Cosmetic Modification (Interior/Exterior/Lighting) 14 06-23-2017 06:11 PM
Winjet foglight experience allowe Cosmetic Modification (Interior/Exterior/Lighting) 7 06-21-2017 11:32 PM
Winjet foglight bulb not coming off golemslord Cosmetic Modification (Interior/Exterior/Lighting) 0 02-18-2016 06:34 PM
Winjet Foglight Instillation IgamaS Northwest 5 01-16-2016 01:39 AM
Winjet foglight install. TheGuyWithTheFireStorm Northern California 0 12-16-2015 02:20 AM
