Northwest AK, ID, OR, WA
Old 01-08-2016, 04:38 PM   #1
IgamaS
Drives: 2015 Whiteout FRS
Talking Winjet Foglight Instillation
Hey you guys, I thought I'd as you first to some help when it comes to installing foglight onto my FRS. I would just like to note that I don't know anything when it comes to wiring what so ever so any advice/tips/tricks would help. I recently bought the winjet foglight and wanting to install them but I have the basics of installing the lights to the frame but not the wiring. If any one can help me out with this, it would be greatly appreciated. I know there may be other post stating the steps but I couldn't find any and I would rather talk to my local group first.
- Stan
IgamaS is offline   Reply With Quote
Old 01-10-2016, 09:26 PM   #2
Mysta316
Drives: 2015 scion FR-S
I just installed these the other day. I read lots of reviews about how easy they are to install and they are just plug and what not. Well I had to file out the holes in the grill inserts because they did not fit over the light enough to be able to click into the bumper cover. also had to file on the tabs of the fog lights themselves to get them to line up with the holes in the bumper cover so you could screw them in. running the wiring was not that bad once I found a good key on power. In the fuse box under the dash there is a unused fuse hole that I just used a spade connector and pushed it into the switched/hot side of it. then there is a ground bolt right by it on the chassis that you can use. The wingjet comes with a connector on the end of the power wire but you will need to cut that off since there is not any place to use that connector.
Mysta316 is offline   Reply With Quote
Old 01-11-2016, 10:51 PM   #3
IgamaS
Thank you for the reply, I just learned and watched lots of videos on how to even though it didn't state any real direction. I did it successfully. Again thanks
Old 01-12-2016, 09:08 PM   #4
Mysta316
no prob. Did your grills fit right in?
Old 01-13-2016, 12:26 AM   #5
IgamaS
My grills some what fit, there are some gaps between the light bulb housing and the grill themselves. What light are you using for your whole front set up? I have 6k LED from VLEDS for fogs, and 5k for DRL, then 6k white and amber for turn signals then 6.5k HID Morimoto system.
Old 01-16-2016, 12:39 AM   #6
Mysta316
I have [ame="http://www.amazon.com/gp/product/B00Y1UXZFW?colid=1FOY0YEFYRZJW&coliid=I1PC5X9XB75T PV&psc=1&ref_=wl_it_dp_o_pC_nS_ttl"]these[/ame] in my fogs with the yellow covers on them. These [ame="http://www.amazon.com/gp/product/B00FC22PVS?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s00"]HID headlights[/ame]. My DRLs are just a yellow bulb but they don't shine yellow very much so im looking at what I want to change them to at some point.
FRS Winjet Foglight red wire install klearfade Cosmetic Modification (Interior/Exterior/Lighting) 14 06-23-2017 05:11 PM
Winjet foglight install. TheGuyWithTheFireStorm Northern California 0 12-16-2015 01:20 AM
Winjet foglight switch problem/discussion Chimera Electronics | Audio | NAV | Infotainment 11 09-09-2015 06:18 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Good place for a clear bra instillation? Maps316 Southern California 4 09-21-2012 03:33 PM
