Old 02-18-2016, 05:34 PM   #1
golemslord
Drives: 2014 White FRS
Winjet foglight bulb not coming off
So I was trying to swap out some foglight bulbs. Removed 3 pins and fender liner. The problem is that the bulb and the power socket doesnt seem to have a way to remove ? Its not like our low beams or highbeams where you push a "button" from the power socket and bulb comes right off. Some help would be appreciated. The foglight kit is winjet. Thanks
EDIT: I got it. Pull the 2 side tabs from the power connector if anyones wondering
golemslord is offline   Reply With Quote
Winjet Foglight Instillation IgamaS Northwest 5 01-16-2016 12:39 AM
Winjet foglight install. TheGuyWithTheFireStorm Northern California 0 12-16-2015 01:20 AM
WINJET H7 Bulb Upgrade HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 6 05-27-2015 08:11 PM
Winjet Bulb went out. dad&sonFRS Cosmetic Modification (Interior/Exterior/Lighting) 2 07-11-2014 10:33 AM
Hid bulb on winjet headlead went out help? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-19-2014 11:56 AM
