Old 12-29-2018, 12:00 PM   #1
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
Installed iJDMTOY 4th brake light today
So today was the day to install the 4th brake light. The install went easier than expected. On iJDMTOY's website there is install instructions:
http://store.ijdmtoy.com/Valenti-Sty...tion-a/617.htm
On my 2019 86 the wiring was different. The OEM brake wire color is GREEN. The OEM tail light wire color is RED. Just an FYI to check your wires before installing as things change model year to model year and car to car. What is so on an FR-S doesn't mean that it will be the same on an 86 and a BRZ.
Don
Modern warriors saddle iron horses of chrome
Dadillac is offline   Reply With Quote
Old 01-03-2019, 01:25 PM   #2
Jay_lately
Drives: 16’frs zn6
Help please
Bro I need your help . I got mine for Christmas and I’m having trouble .
I believe my wires are set up exactly the same .
My ijdmtoy kit has red - brake blue - power black - ground
My issue is that when I connect the
Black - to black ( ground)
Blue - to red (power)
*light is now on *
As soon as I connect the red - power to blue
It cuts off
How did you connect your wires
Jay_lately is offline   Reply With Quote
Old 01-03-2019, 05:03 PM   #3
Dadillac
The wires on the light itself are the brown wire (which is the "V" light) and the blue wire (which is for the brake light). Connect the brown wire to your tail light wire. I used a test light to find the right wire in the factory plug. You need to "extend" the blue wire (I just used one of the supplied wire taps) and attach that to the brake light wire in the factory plug. Again use a test light and see which wire is powered when the brakes are applied. If you have only one function working at a time (meaning only have the tail lights on or only have the brake lights on) you will only have one of the factory wires powered during the testing. Oh and also attach the black wire to the ground wire by the latch. I hope this helps. If not let me know and I can take pics and post them
Don
Old 01-03-2019, 06:48 PM   #4
Jay_lately
Drives: 16’frs zn6
Ah damn you have the actual Valenti light I just have the the led bulb where you drill the hole into your oem housing . Like pictured but newest version
Old 01-03-2019, 08:30 PM   #5
Dadillac
Ah got it. Yeah two different things.
Don
Old 01-03-2019, 08:53 PM   #6
n0thing
Drives: Subaru BRZ
*light is now on *
It cuts off
I made a few posts here.
https://www.ft86club.com/forums/show...99&postcount=5
n0thing is offline   Reply With Quote
DIY REQUEST: IJDMTOY FOURTH BRAKE LIGHT CONVERSION KIT INSTALL SB-86 DIY (Do-It-Yourself) Guides 12 05-25-2018 03:54 PM
Attempting to install iJDMToy 4th Brake light Parappa Cosmetic Modification (Interior/Exterior/Lighting) 25 05-20-2018 09:31 PM
iJDMToy Valenti Brake Light. jesse_86frs DIY (Do-It-Yourself) Guides 22 09-30-2016 10:46 PM
Hi-mount 3rd Brake Light Installed by SpeedZone PNW FRS Northwest 34 11-28-2015 12:42 AM
iJDMTOY flashing 4th break light ReaperX43 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-19-2014 09:57 AM
