Northwest AK, ID, OR, WA
Old 08-27-2015, 02:53 PM   #1
PNW FRS
PNW FRS's Avatar
Hi-mount 3rd Brake Light Installed by SpeedZone
Props to Luke @ SpeedZone for a great install....
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
The Following 5 Users Say Thank You to PNW FRS For This Useful Post:
Ammunition (07-31-2024), HATED1 (08-27-2015), IgamaS (09-02-2015), Premium 615 (08-27-2015), soulreapersteve (08-27-2015)
Old 08-27-2015, 02:56 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
What kit is that?
Is there a plate to block off the stock 3rd brake light?
Thanks!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-27-2015, 03:21 PM   #3
PNW FRS
PNW FRS's Avatar
Originally Posted by JazzleSAURUS View Post
What kit is that?
I bought the "Mustang" kit from American Muscle. $49'ish.
Forum post: http://www.ft86club.com/forums/showthread.php?t=72225
I bought the pre-cut felt pads from the 86'er on the Forum who is selling his Carbon Fiber version (search the Forum). the three pads are peel'n'stick and go over the flat areas of the three mounting points on the rear deck.
Forum post: http://www.ft86club.com/forums/showthread.php?t=87886
You'll still see the depressions. Not a 100% solution for me. I'm going to talk to a local auto upholstery shop to see how much it would cost to have them re-cover the entire rear deck -- do a child seat mount delete at the same time for a clean rear deck. Maybe a good wrap job would work too. The pad solution works for now.
Aside from the cool look from outside-rear... the cleaner view out the back window is great!
2013 Asphalt / MT
Olympia, Washington
The Following User Says Thank You to PNW FRS For This Useful Post:
HATED1 (08-27-2015)
Old 08-27-2015, 04:45 PM   #4
PNW FRS
PNW FRS's Avatar
@Bernie
As if the install wasn't a great way to start a Thursday, Brandon @ S-Zone told me, "Next to Bernie's ride, I like your's next best..."
2013 Asphalt / MT
Olympia, Washington
HATED1 (08-27-2015)
Old 08-27-2015, 05:40 PM   #5
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
Welcome to the club! Looks great!
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
Jonesy86 is offline   Reply With Quote
Old 08-27-2015, 06:58 PM   #6
HATED1
HATED1's Avatar
Drives: 86
I hope @Missy doesn't read this LOL! Thanks for the smile! haha!
86 SESSIONS on Facebook!
HATED1 is offline   Reply With Quote
Old 08-27-2015, 08:13 PM   #7
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
I'm tempted....
*adding to possible mod list*
The Twins make me smile
Old 08-27-2015, 08:21 PM   #8
Missy
Blue Nose
Missy's Avatar
Drives: 2013 FR-S 10 series
So he tags me in it.. makes sense. That made me lawl, my aunt likes mine better than yours too. Poor Bernie, everyone's is better than his :p
Missy is offline   Reply With Quote
Old 08-27-2015, 08:24 PM   #9
Premium 615
Premium 615's Avatar
Drives: '15 BRZ Limited
The aftermarket high mount light looks 1000% cleaner than the factory.
2015 Subaru BRZ Limited AT6
Premium 615 is offline   Reply With Quote
The Following User Says Thank You to Premium 615 For This Useful Post:
Missy (08-27-2015)
Old 08-27-2015, 08:29 PM   #10
DannyQ86
Drives: 2013 frs
Did the shop have to slightly shape the "mustang" light to the rear window or did it sit flush against the glass without any light leak?
DannyQ86 is offline   Reply With Quote
Old 08-27-2015, 09:33 PM   #11
Jonesy86
Jonesy86's Avatar
Nope. Double sided tape takes care of that.
Old 08-27-2015, 09:35 PM   #12
PNW FRS
PNW FRS's Avatar
Not really sure... I wasn't watching the entire process while Luke was squeezed into the back seat area. It seems to fit as flush as it can for $49 mod. I'm not 100% about how the 3m adhesive tape looks on the rear glass... it looks a little too shiny... maybe this will "dull down" a bit with time so that the outline (edges) of the light housing aren't so discernible when you get close-up. From the driver's seat, I'm not noticing any light leak... but will check later this evening when it gets dark.
Update: 9:00 pm.... nope... no leaks that I can tell. From some reflections I saw on a nearby wall, I can tell that the light bar is BRIGHT
2013 Asphalt / MT
Olympia, Washington
Old 08-27-2015, 09:40 PM   #13
PNW FRS
PNW FRS's Avatar
Rear Deck
A quick shot showing the view out the back... I'm going to have to have the rear deck wrapped or re-covered... the OEM mount hole areas are going to bug me...
2013 Asphalt / MT
Olympia, Washington
Old 08-27-2015, 09:43 PM   #14
DannyQ86
Drives: 2013 frs
Cool, I was actually going to order one but just wanted to make sure the plastic matches the bend of the glass to create a nice seal. I've been debating on ordering the 49 dollar one or pulling the trigger on the one made by the guy who sells them on here. Thanks for the pics and point of view. Looks great by the way.
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
Top mount 3rd brake light....off center? Jonesy86 Northwest 44 07-17-2015 05:52 PM
Top mount 3rd brake light Jonesy86 Northwest 1 06-12-2015 02:41 AM
Exogear Car Mount Review - INSTALLED MattQ-WP Electronics | Audio | NAV | Infotainment 10 11-30-2012 02:32 AM
NW Shop Review: Speedzone (Lakewood WA) DarrenDriven Northwest 2 10-19-2012 11:37 PM
