Old 09-16-2016, 12:47 PM   #1
Parappa
Parappa's Avatar
Drives: Scion FR-S White Out
Attempting to install iJDMToy 4th Brake light
I ordered the iJDM Toy 4th brake light the other night. I noticed there is not much space between the bumper and the muffler to take the reverse light casing out.
Is it possible to take the casing out without removing the muffler?
I have watched many install videos and the car is usually on a lift with the muffler out.
Any advice would be much appreciated.
Cheers!
Parappa is offline   Reply With Quote
Old 09-16-2016, 02:53 PM   #2
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
In install videos for that lower brake light with the stock exhaust, they just try to wiggle it out despite being tight. They may lightly tug on the underside of the bumper to help take it out. This is even more of a pain witht the oem diffuser. It will come out eventually.
fizzymike is offline   Reply With Quote
The Following User Says Thank You to fizzymike For This Useful Post:
Parappa (09-16-2016)
Old 09-16-2016, 04:47 PM   #3
Vital
Drives: 2015 BRZ
[ame="https://www.youtube.com/watch?v=-TzYMNrNIas"]iJDM 4th Brake Light Install on Subaru BRZ - YouTube[/ame]
You can maybe follow this installation idk if it'll help much. He bought his from iJDMToy too.
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
Old 09-16-2016, 05:13 PM   #4
Teseo
Drives: frs
Doesnt looks like "plug n play"
Old 09-16-2016, 05:14 PM   #5
FX86
ijdmtoy is rubbish..stay away from their cheap products and shoddy customer service
The Following 2 Users Say Thank You to FX86 For This Useful Post:
Cole (09-20-2016), Parappa (09-16-2016)
Old 09-16-2016, 05:16 PM   #6
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I installed mine without removing the reverse light. just jacked up the rear end and worked on my back. I do have a Borla exhaust though. I may have more room to work than normal.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Old 09-16-2016, 11:11 PM   #7
Parappa
Parappa's Avatar
Thanks I might give that a try if i can't get my hand in there to undo the clips and bolts.
Old 09-16-2016, 11:14 PM   #8
Parappa
Parappa's Avatar
This kit isn't really a product they made....seems like they just sourced out all the material and put it together. Same parts I would have looked for at the local hardware and auto stores.
With kids there isn't too much time so it's easier just to buy it all in one bag.
Old 09-19-2016, 06:13 PM   #9
SlmedFRS
SlmedFRS's Avatar
Drives: Scion FRS, Bagged Lexus IS350
I've been looking at this iJDMTOY 4th Brake Light too for awhile now... Should've ordered it sooner cause now I have no time to install it
Hang on a second I'm lowered
SlmedFRS is offline   Reply With Quote
The Following User Says Thank You to SlmedFRS For This Useful Post:
Jordan Silveira (09-20-2016)
Old 09-19-2016, 09:25 PM   #10
frsq5
Drives: 2014 Scion FR-S Monogram
There are two clips on the bottom of the plastic piece that surrounds 4th brake light.
Once you take those clips out you have more room to work on.
The install for the iJDMToy light wasn't simple plug in and play and requires some wiretapping if you want to enable the 4th brake light and the 'V' running light.
The work I put in to get it working wasn't too bad and it's worth the price.
frsq5 is offline   Reply With Quote
The Following User Says Thank You to frsq5 For This Useful Post:
Old 12-20-2016, 11:55 PM   #11
B$
86
Drives: Monogram Whiteout
what's the kit that is similar to this but when you break it pulses like three times?
B$ is offline   Reply With Quote
Old 01-04-2017, 12:12 PM   #12
86Boyz
Drives: on the highway to hell
it's not really a kit. you will need to install a brake light flasher and wire it in between your brake switch and the rear fog light
https://www.amazon.com/Vehicle-Flash.../dp/B00FADDOL4
86Boyz is offline   Reply With Quote
The Following User Says Thank You to 86Boyz For This Useful Post:
Chimera (01-04-2017)
Old 01-30-2017, 08:48 PM   #13
B$
86
Well gee, I wish I could do that. Wiring and so forth is not my forte...
I thought there was a PLUG AND PLAY kit that did that out there...if anyone knows the name and can link me, I'd appreciate it!
Been looking for awhile for a "3rd/4th" brake light kit...besides Valenti n etc.
Old 01-30-2017, 11:39 PM   #14
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
No such kit exists sadly.
Valentis pulse when you hit the brakes, but the V doesnt stay on as a running light at night without modification and no matter what you have to tap at least the brake wire on your tail lights.
EDIT: if you're afraid of screwing up the stock wiring, check my DIY to make your own harness: http://www.ft86club.com/forums/showthread.php?t=114591
If you make that harness and splice the wires from the 4th brake light to it, it becomes "plug and play" when you actually install it on the car. IMO the hardest part is just getting the light in place and fishing the wiring around the rear bumper.
I was able to do my 4th brake light without a lift or removing the exhaust, but I have the dual canister style exhaust. Not the stock type with a big muffler in the middle. With that said, if you can fit your hand between the gap with a wrench, you can do this without removing the muffler.
PandaSPUR is offline   Reply With Quote
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
DIY: iJDMTOY LED DRL Foglight Bezel Install JDM FRS DIY (Do-It-Yourself) Guides 17 05-20-2019 01:43 PM
iJDMToy Valenti Brake Light. jesse_86frs DIY (Do-It-Yourself) Guides 22 09-30-2016 10:46 PM
iJDMTOY flashing 4th break light ReaperX43 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-19-2014 09:57 AM
Custom Third Brake Light Install (incl. Pics) Skorov AUSTRALIA 14 07-27-2013 04:04 AM
