Old 12-26-2018, 10:24 AM   #1
Silverz
Drives: Black frs
Popping sound when going over bumps and sharp turns
At low speeds.
At high speeds I don’t hear anything.
Took it to a tire shop to diagnose because I thought initially that it was cv joints. They said cv joints were solid and they thought it might be a bad weld and to take it to the dealer to check out. Took it to the dealer and they said it was front right strut. I changed out both with some used ones from eBay and still get the same sound.
Any ideas?
Was thinking maybe a bushing.
Silverz is offline   Reply With Quote
Old 12-26-2018, 10:32 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
May present itself more at low speeds because you're probably turning with more angle. Do you have Aftermarket wheels
Old 12-26-2018, 10:37 AM   #3
Silverz
Drives: Black frs
No everything is factory.
Old 12-26-2018, 04:56 PM   #4
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
do you feel any actual issues while turning or can we move this thread to the "weird noises" section? ^^
HKz is offline   Reply With Quote
Old 12-26-2018, 06:06 PM   #5
humfrz
Originally Posted by Silverz View Post
At low speeds.
Any ideas?
Does it sound like the sound is coming from the front or the back?
Do you have the factory suspension?
Posting a video may help us help you.
humfrz
Old 12-26-2018, 06:34 PM   #6
Silverz
Drives: Black frs
Sounds like the front. Sometimes it sounds like it’s under the dash. Could be the sound traveling through the body though. If I pull into or out of the driveway at an angle I will hear it.
All suspension parts and everything on the car was factory and I replaced the two strut/spring assemblies with factory assemblies.
Old 12-26-2018, 06:57 PM   #7
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
Check sway bar bushings
Don
Modern warriors saddle iron horses of chrome
Dadillac is offline   Reply With Quote
Old 12-26-2018, 07:49 PM   #8
mazeroni
Drives: 2013 Scion FR-S Series 10
Don
I had that on my old '98 Contour. The bushings were bad but they wanted $100 to fix it and that was a nope.
I'll throw my hat into the ring of checking the bushings, but if that isn't it then try to be more specific with the sound. "Popping" is vague and given the history of people who experience weird sounds with these cars and get paranoid most people will tell you to ignore it and be happy it starts, stops, and turns.
If it is repeatable on a specific driveway or bump, film it with your phone.
mazeroni is offline   Reply With Quote
Old 12-26-2018, 09:16 PM   #9
Silverz
Drives: Black frs
Video in link. Pulling out of garage over a 1 inch lip. Popped twice as each wheel goes over lip. Then a pop when straighten out the wheel.
Old 12-26-2018, 09:32 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Sounds like a loose end link. ...maybe.
Old 12-26-2018, 09:41 PM   #11
Silverz
Drives: Black frs
was guessing either tie rod end bushing or sway bar bushings.
Pretty sure they are not loose because I tighten the end links when installing the strut assembly. At least the top nuts i’m Sure of.
Old 12-27-2018, 12:17 AM   #12
highway7
Drives: FRS 2013
For me it was my brake pads getting knocked around, i took them out, regreased, and it worked
If you are not sure, get underneath the vehicle safely and start pushing and pulling parts to see
highway7 is offline   Reply With Quote
Old 12-27-2018, 10:32 AM   #13
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Ball joint maybe? I've had the same thing happen on an older car I owned and it was one of the ball joints.
Check the tie rods as well,but I'm more inclined to think it's the ball joints.
Th3rdSun is offline   Reply With Quote
Old 12-27-2018, 12:35 PM   #14
ermax
ermax's Avatar
EPS? Is it more of a rattle and only on really small bumps like road reflectors or under hard braking? My car sounds like shit because of the gear lash in the EPS. It's only $1400 for a new one. Yippeee!!
Air Releasing sound over speed bumps leevanf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-07-2018 02:53 AM
"Popping" noises going over bumps vividracing Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-15-2015 02:29 PM
Clicking with Sharp Turns carma143 BRZ First-Gen (2012+) — General Topics 7 12-09-2014 12:43 AM
Popping sound retrosmiths Issues | Warranty | Recalls / TSB 30 06-18-2013 01:24 AM
Sputtering sound from right speaker when going over bumps fast? l0aded Electronics | Audio | NAV | Infotainment 2 06-03-2013 02:47 AM
