Old 12-28-2017, 01:52 PM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Air Releasing sound over speed bumps
Hi Guys,
car is just at 5,500 km. all stock.
Just noticed lately that whenever i go over a speedbump, basically whenever the shock is being compressed, (it seems loudest as i HIT the bump, versus AFTER the tire lands on the other side of the bump) there is the slight sound of air being released - like in sci fi movie airlocks. No thunks or anything, just that air being released/ with a slight spring squeaking sound.
As to how loud, if i just creep over the bump, there will be no sound at all. If i take the bump a little faster, but slow enough that there is still no after-bounce, the sound is there. I cannot hear it with windows closed.
This only happens in my front end.
Any clues?
leevanf is offline   Reply With Quote
Old 12-28-2017, 01:56 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I'm going to say that's normal. Or my car is all F'ed up too.
Old 12-28-2017, 02:50 PM   #3
jasonojordan
Drives: 2013 satin white brz limited
What your describing sounds like just the noise the fluid makes as it passes through the valving in the strut.
jasonojordan is offline   Reply With Quote
The Following 3 Users Say Thank You to jasonojordan For This Useful Post:
cjd (12-28-2017), navanodd (12-28-2017), Spuds (12-28-2017)
Old 12-28-2017, 04:27 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sell car, it's totaled. It's going to catch on fire soon. Buy a nice civic.
The Following User Says Thank You to Mr.ac For This Useful Post:
krayzie (12-28-2017)
Old 12-28-2017, 05:06 PM   #5
OND
OND's Avatar
Drives: 2023 BRZ
I also get an air releasing sound sometimes, but it comes from my rear end..
OND is offline   Reply With Quote
Old 12-28-2017, 05:16 PM   #6
bababooey
Drives: BRZ SWP Limited -6MT
does it sometimes leak fluid too?
The Following User Says Thank You to bababooey For This Useful Post:
gravitylover (12-28-2017)
Old 12-28-2017, 06:13 PM   #7
OND
OND's Avatar
Drives: 2023 BRZ
Only after too much sushi
Old 12-28-2017, 07:39 PM   #8
15limited
15limited's Avatar
Originally Posted by leevanf View Post
Hi Guys,
Any clues?
Just double check your struts and surrounding area, make sure they aren't splashed with oil.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 12-29-2017, 05:00 PM   #9
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Too late! Any thread going south with such suddenness can't possibly be put back on track with a single serious answer. Once a gas, always a gas.
(I've heard a little whoosh over speed bumps in other cars, but not my BRZ -- yet.)
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 12-29-2017, 05:03 PM   #10
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Keep this thread going! I am literally LOLing!
winstonscifi is offline   Reply With Quote
Old 01-06-2018, 03:04 PM   #11
SkyKing
Drives: 16 BRZ Limited CWP 82 Alfa Romeo
No air leak but the rears sound like they are bottoming out over small bumps. Checked and rechecked no issues.
SkyKing is offline   Reply With Quote
Old 01-07-2018, 02:53 AM   #12
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
It's the sound of your blow off valve, your car is secretly turbo'd and no one told you
Jk its normal don't worry my BRZ and my old SUV did it too.
"Why must everything that is broken be fixed?"
GhostRai is offline   Reply With Quote
New manual driver - SPEED BUMPS! eifer Engine, Exhaust, Transmission 47 06-16-2015 01:27 PM
M/T and idling over speed bumps - jerking mstoochn Issues | Warranty | Recalls / TSB 7 04-29-2015 04:45 PM
speed bumps jmaryt Scion FR-S / Toyota 86 GT86 General Forum 25 03-05-2014 10:34 AM
Coilovers & speed bumps autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-12-2013 12:36 AM
speed bumps jmaryt BRZ First-Gen (2012+) — General Topics 15 01-20-2013 02:48 AM
