Old 04-13-2015, 08:32 PM   #1
vividracing
vividracing's Avatar
"Popping" noises going over bumps
My BRZ goes over bumps and I occasionally hear a "popping" sound coming from the engine bay, it sounds like some suspension or frame component. I think it's the engine braces just behind the intake manifold but I've checked the bolts and they're secure on there, and I have no idea where it's coming from.
It's gotta be something in the suspension because it only happens if I go over a bump, or a small pot hole or similar, all other times there's nothing, no groaning or anything.
Anybody have had this issue?
-RyanG
vividracing is offline   Reply With Quote
Old 04-13-2015, 10:00 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Are you on stock suspension?
1974 TA22 Celica
2013 86 GT
Old 04-14-2015, 11:43 AM   #3
vividracing
No, H&R sport lowering springs.
Old 04-14-2015, 12:06 PM   #4
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Lowering springs will sometimes cause a popping or creeking noise to be present in rough / bumpy road conditions. Sometimes this is because of the "Bump guard" and sometimes this is because the suspension is physically that much stiffer than stock. There are other reasons too, but even when installed correctly they can rattle, pop, and creek
Old 04-14-2015, 12:18 PM   #5
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I'd also suggest you check the 3 bolts/nuts on your struts where they connect to the body, inside the engine bay. When you changed out your springs and re-installed your struts, did you Loctite the 3 nuts that secure the top of the strut in the engine bay.
When your car is sitting still the strut will appear fine but hit a bump and literally your strut will be popping/slamming into the strut tower mount/body.
This may or may not be the problem.
But if the nuts are loose, secure them with blue Loctite.
Another side note I believe the nuts that secure the strut to the body/tower should be only tightened to around 20ft/lbs. I happen to know for a fact thatif you decide to tighten them a little tighter to say 30ft/lbs, you will shearer the bolt on the top plate of your strut.
I hope this helps.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 04-14-2015, 12:19 PM   #6
8R6
8R6's Avatar
Drives: FRS
bad engine mount? or maybe check all the bushings in the suspension.
that's weird, ive never heard of a complain of a "popping" noise with suspension (springs or adjustable coilovers). usually its some sort of clunking or creaking
8R6 is offline   Reply With Quote
Old 04-14-2015, 12:42 PM   #7
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I actually have this identical problem. I to have lowering springs. I realized the clunk this weekend on a long road trip. I am looking into it tonight. I will post my findings in this thread tonight.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-14-2015, 12:54 PM   #8
vividracing
I haven't always had this popping noise either, it only started about a week ago, and I've had the springs on for nearly a year, and the last time I did anything to the engine bay I repainted the strut braces and I put them back in, I looked at them and tried "jerking" them to see if they were loose when the popping started but wouldn't budge. Also I put them in many weeks before this popping started.
-RyanG
Old 04-14-2015, 01:36 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
neither of these reasons are even remotely responsible for audible popping noises.
Old 04-14-2015, 01:46 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Our problems are sounding more and more eerily similar. I too installed springs almost a year ago.
Old 04-14-2015, 01:48 PM   #11
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Remove strut bars and try going over bumps to see if it makes the same noise. Maybe check your endlinks to see if there is any play/corrosion and retighten as necessary
asdf is offline   Reply With Quote
Old 04-14-2015, 02:25 PM   #12
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Stock sway bars?
If not stock, then pull the front bar and lube the bushings.
celica73 is offline   Reply With Quote
Old 04-14-2015, 02:44 PM   #13
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Stock tophats?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-14-2015, 03:07 PM   #14
vividracing
I haven't changed anything to the suspension other than the lowering springs. Everything else is stock. Perhaps where the shocks attach to the engine bay frame is broken?
-RyanG
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
"thunks" when going over bumps Shipwreck Issues | Warranty | Recalls / TSB 6 06-26-2013 03:28 AM
