Old 05-24-2013, 11:15 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Sputtering sound from right speaker when going over bumps fast?
With OEM Audio+..
A weird problem just started with my upper right speaker (not sure if tweeter or other one). Everything sounds perfect but when I go over rough ground or bumps at freeway speeds it makes a sputtering sound similar to the sound that you hear when you plug in speakers and touch the metal before it goes all the way in.
- The sound still happens when the stereo is off. The loudness of the sound does not change even if I change the volume.
- I took out the plate covering the tweeter and speaker when the car was stagnant and played some music and hit the tweeter lightly as well as the other speaker but could not recreate the sound.
- I have an OEM Audio+ set but have had it for the last few months. The tweeter seems to be fine as I can hit it hard and it doesn't sputter.
- The only wiring changes I made around the area is I tapped the wire going into the cigarette lighter in the glove compartment for LED strips. This was done using quick connects so I doubt it would affect it.
any ideas =/?
l0aded is offline   Reply With Quote
Old 05-25-2013, 08:53 PM   #2
l0aded
Addicted
l0aded's Avatar
Nothing?
Old 06-03-2013, 02:47 AM   #3
l0aded
Addicted
l0aded's Avatar
Well I believe I figured out the problem. The sputtering sounds were coming from my tweeters and it looks like the foam around the tweeters has been depressed heavily causing the top of the speaker dome to hit the cap covering the tweeter. I e-mailed OEM Audio+ about the issue asking if there is a known fix or if I can RMA the tweeters. Picture attached.
Front suspension squeak going over bumps Gords_zenith Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-19-2017 09:57 AM
speed bumps jmaryt Scion FR-S / Toyota 86 GT86 General Forum 25 03-05-2014 10:34 AM
speed bumps jmaryt BRZ First-Gen (2012+) — General Topics 15 01-20-2013 02:48 AM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
