Old 12-10-2018, 02:12 PM   #1
kingaron06
Drives: 2017 Subaru BRZ
Exclamation P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced
So I got this code on my BRZ and I've replaced the OCV with a genuine one from Subaru. I've also done an oil change after the light came on so I know that its not the oil's fault on why this code is popping up. And there's also a knocking noise coming from the same side of the block. I'm pretty sure that they are both related but then again I could be totally wrong. I've also tried to clear the code multiple times but it'll come back on the third time I start it after clearing. I've been stuck on this issue for over a month now. Will I have to rebuild the block or is it still safe? Any info would help.
kingaron06 is offline   Reply With Quote
Old 12-10-2018, 02:37 PM   #2
Are you not still in warranty?
Old 12-11-2018, 12:40 AM   #3
kingaron06
No it's not It's a salvage because it was hit from the back.
WTB: Camshaft Timing Oil Control Valve Assembly Connector driftking96 Want-To-Buy Requests 8 05-18-2022 07:02 PM
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Camshaft timing oil control valve assembly - P0013 smellslikecurry Issues | Warranty | Recalls / TSB 8 11-02-2016 09:53 AM
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 11:38 AM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
