Old 11-28-2018, 12:52 PM   #1
gt7877
Drives: turbo frs
Question EcuTek pops tune (sport mode)
Dear
How can to tune stock ecuTek rom for pops and backfire ??
I have 2013brz has ecuTek license
It was turbo
But now he revers to stock
Just he need pops and back fire
I have stock ecuTek rom and cable + USB dongle
I need to activate pops just at sport mode
Thnx to all
gt7877 is offline   Reply With Quote
Old 11-28-2018, 02:37 PM   #2
tomm.brz
Drives: brz 2017 hksv2
Do you have racerom license? (350$ more or less)
without it you can t modify stock roms, neither use custom maps
Old 11-28-2018, 02:52 PM   #3
gt7877
Drives: turbo frs
Yes there is racerom
Old 11-29-2018, 01:00 PM   #4
gt7877
Drives: turbo frs
any update
Old 11-29-2018, 01:53 PM   #5
tomm.brz
Can t make screenshots in these days,
You need to create a custom map, make its X-axis and Y-axis identical to your Ignition advance map VVt on (X is engine load, Y engine rpm), and then on the first column (usually 0.15 load) fill the table from 3k rpm to redline with , for example,a value of -40
On the custom map "enable" table, put a tick on the map you want it to work on, AND on "enable map in Vsc Sport mode" only
Custom map "output definition" table: Ignition Base timing, Add map output to channel value
The Following User Says Thank You to tomm.brz For This Useful Post:
gt7877 (11-29-2018)
Old 11-29-2018, 02:02 PM   #6
gt7877
Drives: turbo frs
You need to create a custom map, make his X-axis and Y-axis identical to your Ignition advance map VVt on (X is engine load, Y engine rpm), and then on the first column (usually 0.15 load) fill the table from 3k rpm to redline with , for example,a value of -40
thnx alot
right now ecutek cable not with me to open proecu
can u plz send some images for reverance
ill try too do it 2morrow
thnx again
Old 11-30-2018, 03:49 AM   #7
tomm.brz
i m few days away from my car and computer, follow my post and you shouldn t go wrong, in case post screenshots
Old 12-20-2018, 01:19 PM   #8
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Why would you need to make a custom map? Because you only want it active in sport mode? You could also just pull timing out of the ignition table for tune two. Same idea? Have tune 1 normal and turn 2 crackle.
Toyota John is offline   Reply With Quote
Old 12-20-2018, 02:29 PM   #9
tomm.brz
Yes to have it. With vsc sport, it s good also to have it on command like that instead of dedicate one entire map to it
Pops/Crackle Tune do damage to your brz? Jcas Software Tuning 79 01-26-2022 10:29 AM
Sport Mode pops gt7877 Software Tuning 3 11-20-2018 04:37 AM
OFT Pops and Crackle Tune problem V4 niceman Software Tuning 8 09-16-2018 09:27 PM
Ok to drive sport mode on OFT tune? timmydatooth Software Tuning 4 04-14-2017 05:08 PM
