Old 09-16-2018, 03:46 AM   #1
niceman
Drives: 2017 GT86
OFT Pops and Crackle Tune problem V4
hi
I don't know what's going on?
this is my pops tune base on v4. it does not work. Can someone help me?
i have catless header overpipe and catback.
niceman is offline   Reply With Quote
Old 09-16-2018, 06:08 AM   #2
tomm.brz
Drives: brz 2017 hksv2
are you touching lightly the throttle during overrun? try maybe a littlenmore negative and do something like -6 on 0.2 load column
Old 09-16-2018, 06:57 AM   #3
niceman
Drives: 2017 GT86
which rpm on 0.2
Old 09-16-2018, 07:10 AM   #4
tomm.brz
i would start from 1200rpm on 0.15load and 2000 on 0.2load
anyway this way of doing pops requires to touch the throttle very lightly during overrun, otherwise the fuel cut would be present and no pops
Old 09-16-2018, 12:05 PM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You have a catless FP too right?
Old 09-16-2018, 01:17 PM   #6
tomm.brz
some pops should come out with totally stock car. From what i undeestood he got nothing at all
Old 09-16-2018, 06:56 PM   #7
niceman
Drives: 2017 GT86
I don't have it. Only stock FP. Is it not work?
Old 09-16-2018, 07:00 PM   #8
niceman
Drives: 2017 GT86
Yes. As you said. I will try your advise
Old 09-16-2018, 09:10 PM   #9
guybo
Huge E85 fan!
guybo's Avatar
the FP cat is killing your pops and bangs.
what catback do you have?
Old 09-16-2018, 09:27 PM   #10
steve99
should work i have stock front pipe and it wrks fine with catless header and aftermarket catback.
If you have stock catback it doesnt rearly work
log the ignition timing and see if your actually getting negitive values on overun, if not check you actually flashed correct tune
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
OFT Pops and Crackle Tune just stops working after a while? stig_iv Software Tuning 12 08-21-2018 05:30 PM
Question about crackle and pop.. Qc86 Engine, Exhaust, Transmission 10 12-03-2017 01:49 PM
Openflash tune problem with brz sgoldberg01 BRZ First-Gen (2012+) — General Topics 6 02-09-2016 01:13 PM
map problem ecutek tune. ChinoAnthrax Software Tuning 8 05-05-2014 02:57 PM
