Old 11-22-2018, 01:59 PM   #1
scsftballnum45
Drives: BRZ 14'
OFT Stalls on Cold Start
Today is the first time my car was started in 10 degree weather. It started fine, but stalls when I release the clutch. I had to hold the gas for awhile to prevent it from stalling again. I have OFT stg 2 plus. Any advice on a fix?
scsftballnum45 is offline   Reply With Quote
Old 11-22-2018, 07:47 PM   #2
steve99
You on e85 ? Or petrol
Old 11-22-2018, 08:58 PM   #3
scsftballnum45
Drives: BRZ 14'
Petrol
Old 11-23-2018, 01:07 AM   #4
steve99
Petrol
increase base idle speed in the idle tables at those temps where you have issue
double the values in lines 1 and 2 of the maf correction after start tables both in gear and in neutral at the teps your having issues at and at temps below below
Old 11-23-2018, 12:20 PM   #5
scsftballnum45
Drives: BRZ 14'
Okay, I’ll try it when I get home. Thanks!
Old 02-01-2019, 09:53 PM   #6
scsftballnum45
Drives: BRZ 14'
Tomorrow my car will be outside in the cold and I can’t find maf correction after start in rom. Where is it?
Old 02-01-2019, 10:22 PM   #7
steve99
Your defs may not jave those tavles defined
What is your calid ill see if i have a better definition
Old 02-02-2019, 02:07 AM   #8
Mr_Eyo
Drives: 2017 Toyota 86
I think it's either in A/F Sensor or Fueling - Cranking?
Mr_Eyo is offline   Reply With Quote
Old 02-02-2019, 08:08 PM   #9
scsftballnum45
Drives: BRZ 14'
My Calid is za1jb01c
Old 02-14-2019, 02:07 PM   #10
scsftballnum45
Drives: BRZ 14'
Any luck on a different rom definition? I found a photo of where it should be and it’s definitely not on the one that came from OFT.
Old 02-14-2019, 03:03 PM   #11
tomm.brz
Drives: brz 2017 hksv2
Steve has always EVERYTHING anyboy would ever need about tuning this car's ecu, in his signature's links
http://www.ft86club.com/forums/showp...&postcount=411
first definition is good for you if you have a B01C tune
Old 02-14-2019, 04:47 PM   #12
steve99
You using oft v4 or older v2 tunes ?
Old 02-14-2019, 05:44 PM   #13
steve99
If your oft v4 tune use defs here, you will need to modify calid in def this is for 2012-2016 cars
http://www.ft86club.com/forums/showthread.php?t=126180
Old 02-17-2019, 02:25 PM   #14
scsftballnum45
Drives: BRZ 14'
Yes, I'm using V4. So the 2012-2016 A01G will work fine with my B01C?
BRZ down... Stalls right after start bravedeer Issues | Warranty | Recalls / TSB 12 09-12-2018 06:39 AM
E85 + OFT + headers: stalls out on cold start ixobelle Engine, Exhaust, Transmission 8 05-16-2017 11:52 AM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
