Old 08-31-2017, 07:53 PM   #1
bravedeer
Drives: Subaru BRZ 2013 Limited Manual
BRZ down... Stalls right after start
The BRZ I bought about 2 months ago came with the following condition:
You start, it runs for about 2 secs then it stalls. The second time you start it always runs fine. Condition went away for about 2 weeks.
But today, when I was 2 hours away from home, instead of starting after the 1st try, it kept doing the same thing over and over. For nearly 20 minutes. I took an uber ride to an appointment, came back an hour later and the same thing kept happened.
As the tow truck was headed my way, it started, I drove to a dealership and left it there.
It NEVER EVER stalls after it's running. It runs insanely great. Nobody has any idea what's going on...
Anyone?
bravedeer is offline   Reply With Quote
Old 08-31-2017, 09:36 PM   #2
humfrz
Does the car have any power mods .... ??
How many miles on it .. ??
My first "guesses" would be related to a fuel problem.
* water in the gas
* clogged fuel filter
humfrz
Old 08-31-2017, 10:03 PM   #3
dutchman1
Drives: 2017 86 6-Speed
Does it still stall if you have your foot on the throttle while you start it?
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 09-01-2017, 12:02 AM   #4
radroach
Drives: car
Wait for your dealership diagnosis. Surely there's something they'll point to as the problem.
Old 09-01-2017, 06:33 AM   #5
bravedeer
I'm not a mod guy. When I bought it the dealership said they had reset the ECU to factory. The only mods we know of is the air filter and inlet take hose which gets rid of the resonator. They gave me a "certified" pre-owned warranty till 100k, and right now the car has 45k.
* water in the gas
humfrz
Old 09-01-2017, 06:35 AM   #6
bravedeer
Yeah, I tried revving it for those 2 secs it's on to see if it still stalls and it does. It feels like the computer is deliberately cutting the gas. It has never once stalled when it's running, even at the 500rpm idle
Old 09-01-2017, 02:34 PM   #7
bravedeer
Dealership thinks it's the immobilizer antenna unit...
Old 09-01-2017, 07:11 PM   #8
Zentec
Drives: 2017 Toyota 86
I would check the clutch sensor. It is a little switch that when you press the clutch it allows the car to start. I have seen this in several brz around me. It's an easy fix.
It bothers me that the dealer said they reset the ecu to oem. If it had been flashed before maybe something didn't get put back on right.
I'm with humfrz could also be fuel filter.
I would think if it's the immobilizer ant that it would either work or not.
Zentec is offline   Reply With Quote
Old 09-01-2017, 07:22 PM   #9
bravedeer
I don't think it's the clutch sensor because the car does start. It runs for 2-3 seconds until power is cut off.
Old 09-02-2017, 12:39 AM   #10
dutchman1
If it drives fine once it runs, the only real ignition coil trouble you could have is bad coil boots. But that would resolve with more throttle.
A failing fuel pump doesn't typically behave the way you're describing.
There is a host of other little mechanical things that can cause a car to start and die; sticky throttle bodies, vacuum leaks, fuel filters/regulators, etc, but I can't think of one where the car would still run flawlessly once it started.
I'm leaning towards it being a sensor issue. Most likely MAF or O2 related. Take my advice with a grain of salt but that's where I'd start looking.
Old 09-11-2018, 10:44 PM   #11
Martin666
Drives: 2016 Subaru Brz
I have the exact same problem.This is the only thread I found.
Push start brz 2016 20000Km. Overhere. No mods. 110% stock No codes. Daily driven.
NOTHING out of the ordinary. Normal/spirited driving
Always(almost) fuel up at the same Shell station.
It happens randomly. Hot or cold, left, right or center. It starts, runs for 1- sec. then blah! It just dies. no burps, studders, just instant death. Like the ECU is going oh hell no you're not! Press the button again and it starts back like everthing's honky dory and runs so for weeks/months.
Bothered, the dealer will obviously find jack squat is wrong.
I doubt "Shut up and give me a free ecu Reflash" would work well.
Martin666 is offline   Reply With Quote
Old 09-12-2018, 05:00 AM   #12
steve99
There no updated ecu firmware for any car past mid 2013
Of you have diagmostic toll check the long term fuel trims at idle valies over 10% isually indicate a problem like intake or exhasut leaks
Check the map manifold pressure sensor reading with ignition on but engine stopped should be 1 bar ie armospheric or 14psi, when engine idling should be about 0.3 bar or 4psi. If it wildly different then again you may have air exhaust leak or the map sensor is faulty.
Also try cleaning MAF mass air flow sensor
Check afr at idle is aprox 14.7
Old 09-12-2018, 06:39 AM   #13
ermax
ermax's Avatar
Because you say it starts perfectly fine without hesitation and is perfectly smooth I’m going out on a long limb and thinking maybe something related to the immobilizer system. I’m not sure about the Twins but on cars I’ve had in the past they would actually start and run for a few secs before the computer would shut it off because it wouldn’t see the transponder. I actually have a key that isn’t paired yet. I will give it a test for shits and giggles.
Edit: Oh never mind missed the part were you said it runs fine the second start.
E85 + OFT + headers: stalls out on cold start ixobelle Engine, Exhaust, Transmission 8 05-16-2017 11:52 AM
FR-S - AT nearly stalls when stopping WryGuy Issues | Warranty | Recalls / TSB 12 05-27-2016 03:04 PM
Replaced liquids with motul 300.... Car stalls... Vroomin86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 11-03-2015 02:03 PM
Automatic FR-S randomly stalls when Idling LzT AngeL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 12-15-2014 08:31 AM
Car almost stalls but clutch is all the way in when stopped LaertesSon Engine, Exhaust, Transmission 11 05-13-2014 05:55 PM
