Old 11-19-2018, 09:52 PM   #1
xanielxx
Drives: 2016 Scion FR-S
Question 2016 FR-S making Weird winding sound
So I started my car up this morning, nothing out of the ordinary but after a minute or so, my car started to make a weird winding up noise. I left my car idling for several minutes and I came back to it still making that noise. I thought it was my sound system, so I turned that off and it was still going on. So I just decided to turn my car off. It still kept making that noise after about 15 seconds. My car is all stock, for the most part. I’m not sure how I can upload the video of it. But I’d appreciate any info
xanielxx is offline   Reply With Quote
Old 11-19-2018, 10:40 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Can you pin point where the sound coming from?
Sent from my SM-G935T using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 11-19-2018, 10:58 PM   #3
xanielxx
It sounded like it was coming from the center of the cabin, near the dash
Old 11-19-2018, 11:38 PM   #4
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Weird. Was the AC on? Any way you could describe the winding noise? Did it eventually go away? Any previous issues?
Will BRZ is offline   Reply With Quote
Old 11-19-2018, 11:42 PM   #5
xanielxx
The closest I can describe the sound is like a dvd being rejected or put in. Today was the first occurrence, just started up my car twice and it seems fine
Old 11-19-2018, 11:43 PM   #6
xanielxx
AC was off as well. I was told by other that it could be AC, HID, or fuel pressure pump
Old 11-19-2018, 11:47 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Cooling fan in the head unit took a shit. It's a thing.
Old 11-19-2018, 11:48 PM   #8
xanielxx
Is it an issue? Or fixable?
Old 11-19-2018, 11:50 PM   #9
Ultramaroon
not playing cards
It's a common little fan. I don't remember if soldering is required.
Old 11-19-2018, 11:50 PM   #10
xanielxx
How does that even happen though?
Old 11-19-2018, 11:56 PM   #11
Ultramaroon
not playing cards
Teeny tiny bearings give out. It's a numbers game. For 10,000 fans, one or two have exactly the right combination of blades out of balance and/or whatever else imperfect. Those shit the bed earlier than the rest.
Old 11-20-2018, 12:02 AM   #12
xanielxx
Thanks man. Nothing worry then?
Old 11-20-2018, 12:30 AM   #13
BlOody_BoOger
I think i get that exact same sound too when i shut the car off sounds like a disc ejecting then a small click at the end
Old 11-20-2018, 12:31 AM   #14
Ultramaroon
not playing cards
Not exactly. Once the fan quits altogether, the rest of the head unit will overheat. But that's all.
frs
Making the BRZ sound better TheYetiBRZ Engine, Exhaust, Transmission 17 10-16-2017 09:05 PM
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 05:33 PM
Turn signal stalk making weird high pitched noise. FRS-Learner Issues | Warranty | Recalls / TSB 6 11-07-2015 08:54 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 06:06 AM
