Old 12-09-2013, 08:43 PM   #1
B_Rad
B_Rad's Avatar
Drives: 2013 Scion FR-S/Raven Black/6 sp mt
Car won't start! Making weird sounds.
Car has been sitting for a few weeks as it'a not a daily. Went to start it the other day and the starter won't engage. Battery has 12.5 volts. Attached is the video of the sound it makes.
Updated!!!
Replaced the battery and car still wouldn't start. So I "jump" started it by bypassing the factory harness and took a wire directly to the solenoid on the starter to the battery with the key on. The car started right up. I took it on a drive to get it up to running temperature and then shut it off. Tried to restart and it fired right up. So I let it sit overnight and tried to start it again today and same thing won't start. It is still not giving me any codes. All the fuses are good and nothing else if having problems besides my air ride control quit working but that is its own issue and I'm waiting on a replacement to get here from Airlift.
B_Rad is offline   Reply With Quote
Old 12-09-2013, 08:51 PM   #2
humfrz
Well, your car's battery can show 12 volts and still not have enough juice (amps) to run a starter.
Do any lights come on?
I suggest you put a battery charger on it for a spell. Or, take the battery out and have it charged.
You might check to make sure the battery terminals are clean and tight.
I hope you get er running!
PS - I don't see/hear any video??
Does it sound like ... click..click.. ??
humfrz
strat61caster (12-09-2013)
Old 12-09-2013, 09:02 PM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
does the car say "GET OUT" in a creepy demonic voice? That may be a bad sign.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
B_Rad (12-09-2013)
Old 12-09-2013, 09:03 PM   #4
B_Rad
B_Rad's Avatar
working on getting video loaded. All lights come on. I get no click,cant even get the starter to engage.
Old 12-09-2013, 09:33 PM   #5
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
I will put my money down it is a bad battery.
AVodka14 is offline   Reply With Quote
The Following 2 Users Say Thank You to AVodka14 For This Useful Post:
Opie (01-03-2014), strat61caster (12-09-2013)
Old 12-09-2013, 09:37 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Clutch button works? 12.5 volts should spin the starter.
Rayme is offline   Reply With Quote
Old 12-09-2013, 09:41 PM   #7
B_Rad
B_Rad's Avatar
Second thing I checked. It is working
Old 12-09-2013, 09:43 PM   #8
SkullWorks
Drives: SSM LT MT BRZ
have someone attempt a crank while you are checking voltage and see what it drops down to.
SkullWorks is offline   Reply With Quote
Old 12-09-2013, 09:45 PM   #9
B_Rad
B_Rad's Avatar
^ was going to try but then started making the noise posted in the video. (Just got it loaded)
Old 12-09-2013, 09:45 PM   #10
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
That noise is the throttle butterfly servo motor (press on the gas pedal it should change sound). No idea about the no start.
Old 12-09-2013, 10:52 PM   #11
strat61caster
strat61caster's Avatar
Any aftermarket mods?
Sounds like a dead battery to me, try a jump start and drive it around (not far) to give it a good charge (more than half an hour I think).
ineedyourdiddly
Old 12-09-2013, 11:04 PM   #12
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Try push-starting it, maybe? If it starts, drive around and let the battery charge, like strat61caster said.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 12-09-2013, 11:14 PM   #13
humfrz
Well, it's my understanding that a battery can show 12 Volts, which may just be a surface charge. A "bad" battery which shows 12 surface volts, will drop to a point well below 12 volts and cannot transfer enough amps to turn over a starter.
So, I like strat61caster's strategy ...... jump that puppy and see if it will hold a charge. If it doesn't, take it in and have it "load" tested to see if it's being a bad boy.
humfrz
strat61caster (12-12-2013)
Old 12-09-2013, 11:29 PM   #14
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
humfrz
Well there's a big difference between 12.0 and 12.5!
12.6 is a fully charged battery. 12.0 flat is a battery needing a charge. But we're all waiting on OP to boost 'er up and see what happens.
Weird sounds and liquid dripping from car kam Issues | Warranty | Recalls / TSB 21 05-07-2014 07:01 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
