Drives: 2016 BRZ Limited
Coilover supporting mods?
Hey guys, I'm getting ready to purchase coilovers for my BRZ, and I'm thinking of going with the Tein Flex Z (or A).
I plan on getting rear LCA's, and I was wondering if I would need front end links as well? I've read a lot about the stock end link bolts rusting together, requiring cutting. Would I be good with regular end links, or should I get adjustable? Are there any recommended brands for LCA's/End links, and do you guys think I'd be better off splurging on the Flex A's for my daily driver? If it helps, I don't plan on going very low, maybe 1-1.5" at the most. Thanks! |
#2 | |
If the tein's don't come with end links you are fine to re-use originals. |
Drives: FR-S Turbo
I'd recommend taking a serious look at the CSG-spec Tein Flex A over the standard issue ones. More money, but light years ahead in terms of performance.
They are custom valved and sprung - and track-tuned by a VERY fast 86-platform driver who really knows his shit. Sounds like a new shipment of them has just arrived, too. Contact Mike @ Counter Space Garage to discuss: |
#4 | |
I've used track focused coils for some of my club cars, brilliant on the track but a nightmare on the street. In saying that, I am by no way saying they are a bad choice, unless you do alot of driving on sub par roads. I would say yes to needing at least new front links. I only have a 20mm drop and required new front links.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
Country Boy 4 Life
Both of those sets of coils have front camber adjustment. But, not rear. You would need LCA's to adjust rear camber.
I LIKE TIRES! |
#6 | |||
Thanks for the replies, everybody. To reiterate, this car won't be seeing track time, so comfort is definitely a plus. If the Flex A is really that much better than the Z, I don't mind spending a little more. If there are other recommendations, in terms of brands for both Coilovers & LCA's, I'm open to further suggestions! I'm assuming end links don't need to be adjustable, so if I did get a new set, a standard one-size should be fine, correct? I'm not really sure how much tension/preload would be put on the sway bar if I lowered by 1", respectively. |
#7 | |
The only downside is that they're not flashy, and look like stock lcas. Not sure if that's something you would consider, but I did see that this would be your show car.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#8 | |
$200 on eBay or amazon, it’s a good choice for those who don’t want spherical bearings in their lower control arms. |
#9 | |
Drives: Subaru BRZ / Toyota 86 Experts
| WTB Turbo and supporting mods | OzzyGT86 | Want-To-Buy Requests | 2 | 08-26-2017 06:14 PM |
| E85, what are the best supporting mods? | ProjectMidnight86 | Engine, Exhaust, Transmission | 9 | 06-25-2016 02:56 PM |
| What supporting Mods do you REALLY need? | Adrian002 | Forced Induction | 27 | 05-09-2015 08:27 PM |
| Supporting Mods For F/I Applications | Tansey86 | Forced Induction | 59 | 02-26-2013 01:42 AM |
| Supporting Mods | Double4Free | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-21-2012 05:33 PM |
