Old 10-29-2018, 01:23 PM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
excess rear brake dust
For some reason, i have a significant amount of brake dust build up in the rear when compared to the front. This started when i installed SS brake lines, replaced oem brake fluid with RBF600 and started using Ferodo DS2500 pads (Front and rear). Not even sure if its an issue. Car is handling fine after a full Autocross season and several track days. Should i change the rear pads back to OEM?
I've also turned off TC to see if its because of the ECU freaking out with my suspension and tires, but doesn't seems like its making a difference.
slyphen is offline   Reply With Quote
Old 10-29-2018, 01:28 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Check to see if rear calipers are sticking. Inspect rear pads.
N1rve
Old 10-29-2018, 01:33 PM   #3
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
If you aren't doing the pedal dance your TC is still trying to "help" by using the rear brakes.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 10-29-2018, 01:59 PM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
This
I seen porsches melt their rear brakes on track
Old 10-29-2018, 02:55 PM   #5
slyphen
Drives: Man
so like do i do anything about it? or do i just have to deal with the dust, if that is the case?
Old 10-29-2018, 03:06 PM   #6
strat61caster
strat61caster's Avatar
Get some more coaching and seat time, TC is subtle as a hammer in the '12-'16 cars except for the brake biasing. Could be that but I doubt it because DS2500 shouldn't survive hot lapping unless you're well under the limit.
@N1rve is right, check for sticking caliper, clean everything up and keep an eye on it.
ineedyourdiddly
Old 10-29-2018, 03:16 PM   #7
Takumi788
JHerbert Racing
Takumi788's Avatar
I briefly looked at your build thread and I see you run STX in your avatar. I have no idea what is allowed in STX but check out the beastronix 86nanny. The 86nanny does the pedal dance at the flip of a switch.
https://www.beastronix.com/86nanny-pedal-dance/
Old 10-29-2018, 03:36 PM   #8
slyphen
Drives: Man
I dont think it has anything to do with my driving. The car is also my daily, i'm getting dust from just high way driving. i'll check for sticky caliper again, but last i checked, rear hub was able to spin freely.
Thanks
Old 10-29-2018, 04:32 PM   #9
strat61caster
Yeah than the TC/pedal dance isn't going to change anything unless your high way driving consists of you trailbraking into consecutive on-ramps for a half hour every day and lifting a wheel off the ground.
It was not obvious from your post whether you are observing the dust due to DD or autox/track.
ineedyourdiddly
A lot of brake dust on passenger rear wheel DTMdreaming Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-26-2018 03:32 AM
Performance Pack Brake Dust? Opie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-03-2017 11:47 AM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 09:30 AM
brake dust? Capstan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-13-2012 06:35 PM
Brake pad dust yomchi1989 AUSTRALIA 7 08-19-2012 01:08 AM
