Drives: Man
excess rear brake dust
For some reason, i have a significant amount of brake dust build up in the rear when compared to the front. This started when i installed SS brake lines, replaced oem brake fluid with RBF600 and started using Ferodo DS2500 pads (Front and rear). Not even sure if its an issue. Car is handling fine after a full Autocross season and several track days. Should i change the rear pads back to OEM?
I've also turned off TC to see if its because of the ECU freaking out with my suspension and tires, but doesn't seems like its making a difference. |
#2 | |
Drives: 2019 BMW ///M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#3 |
JHerbert Racing
Drives: 2013 Scion FRS
If you aren't doing the pedal dance your TC is still trying to "help" by using the rear brakes.
| The Following 3 Users Say Thank You to Takumi788 For This Useful Post: |
#4 | |
Thanks
I seen porsches melt their rear brakes on track
| The Following User Says Thank You to ZionsWrath For This Useful Post: | Takumi788 (10-29-2018) |
#5 |
Drives: Man
#6 | |
Drives: '13 FRS - STX
@N1rve is right, check for sticking caliper, clean everything up and keep an eye on it. |
#7 | |
JHerbert Racing
https://www.beastronix.com/86nanny-pedal-dance/
#8 | |
Drives: Man
Thanks
#9 |
Yeah than the TC/pedal dance isn't going to change anything unless your high way driving consists of you trailbraking into consecutive on-ramps for a half hour every day and lifting a wheel off the ground.
It was not obvious from your post whether you are observing the dust due to DD or autox/track. |
| A lot of brake dust on passenger rear wheel | DTMdreaming | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-26-2018 03:32 AM |
| Performance Pack Brake Dust? | Opie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-03-2017 11:47 AM |
| Brake dust or rail dust? Dealership bs? | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 12-21-2013 09:30 AM |
| brake dust? | Capstan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-13-2012 06:35 PM |
| Brake pad dust | yomchi1989 | AUSTRALIA | 7 | 08-19-2012 01:08 AM |
