Old 05-26-2018, 01:02 AM   #1
DTMdreaming
Drives: 13' Raven FR-S 6 sp-Manual
A lot of brake dust on passenger rear wheel
The passenger side rear wheel on my FR-S has a lot more brake dust than the other wheels. I changed the rotors and pads about 6 months ago, however I did not clean and re-lubricate the slide pins. Could it be a stuck caliper? I had this problem on my Forester and that seemed to fix the problem but it was all 4 in that case. What are some of your thoughts? Thanks.
DTMdreaming is offline   Reply With Quote
Old 05-26-2018, 03:32 AM   #2
CraigVM
Drives: Car Collector
Sounds like you nailed it
From the dozens of "how to" videos I have recently watched regarding brake jobs many have stated excessive dust being caused by stuck slider pins as you are suspecting. They also mention worn pistons causing the same by not receding and keeping the pads against the rotors. Perhaps a good way to test is a drive a bit then coasting to a stop maybe using a steep hill to do so. If the problem wheel has a warm / hot rotor while the other side does not ??
CraigVM is offline   Reply With Quote
Performance Pack Brake Dust? Opie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-03-2017 11:47 AM
Buzzing from rear passenger wheel Mattybro410 Issues | Warranty | Recalls / TSB 1 11-04-2014 09:25 AM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 09:30 AM
brake dust? Capstan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-13-2012 06:35 PM
Brake pad dust yomchi1989 AUSTRALIA 7 08-19-2012 01:08 AM
