Old 10-23-2018, 01:27 PM   #1
atomicalex
Drives: 2018 BRZ Limited Perf Pack
Ambient light sensor location?
Where is it? (ok to point me to the manual)
'18 here, and the entire dash seems to dim and brighten as it pleases. This is driving me batty.
Anyone know?
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Old 10-23-2018, 02:08 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
This is stated at the very beginning of your Owner's Manual on the diagram that identifies all the parts of your dash...
...but I'm feeling particularly generous at the moment, so it's the little round hump on the dash towards the base of the windshield. If it's a LHD car, it's towards the right side.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
atomicalex (10-23-2018), JohnJuan (10-24-2018)
Old 10-23-2018, 03:09 PM   #3
atomicalex
Thank you....
Are they known to be finicky, or is mine just special?
www.atomicalex.com
Old 10-23-2018, 03:12 PM   #4
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Page 235 of the 2018 manual goes into specifics on this.
As far as I know, if you have the headlight stock set to "auto" this is what's causing your dash to brighten/dim in changing light conditions. It is tied to when the sensor turns on your headlights. Only way to keep the dash at full brightness all the time is to have your headlights switched to fully on.
wolffbite is offline   Reply With Quote
Old 10-23-2018, 03:12 PM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by atomicalex View Post
Thank you....
It will turn on and off your lights when it senses the need to. Like if you're driving through a tunnel, parked in a dim garage etc etc.
Old 10-23-2018, 03:14 PM   #6
Stang70Fastback
A.K.A. Starlord
I've never had an issue with mine. However, I don't think it adjusts the dash lights at all. At least I've never noticed that. Perhaps the refreshed vehicles are different as a result of the digital screen in the instrument cluster.
The only thing that affects instrument panel lighting for me is what I do with the headlight switch, or the dimmer switch. The ambient light sensor is used for other things like determining when to switch your automatic headlights on/off, and how to run the HVAC based on how much sunlight is entering the cabin. Again, though... maybe that changed for 2017.
Old 10-23-2018, 03:27 PM   #7
atomicalex
I appreciate the background.
My headunit and dash occasionally dim and brighten for no apparent reason at all - it goes into low light mode - and I am trying to sort out if the sensor is flaky or what. The cluster is definitely linked to the HU by both dimmer switch and the sensor. I have to change the dimmer setting to see anything during the day when it is flakeout mode.
I do run my headlamps on all the time, I wonder if it just hates me?
I will check into my settings and see what I can find. Ideally I will find a pot that I can adjust it with!
www.atomicalex.com
Old 10-23-2018, 03:29 PM   #8
Stang70Fastback
A.K.A. Starlord
Your Owner's Manual explains exactly how to adjust the light sensor's sensitivity...
Old 10-23-2018, 03:55 PM   #9
wolffbite
Just the tip
wolffbite's Avatar
Hmmm, I've looked through both the 2015 and 2018 manual now and they both say it is something that can only be changed at a dealership? Page 447 for the 2015 manual and page 524 for the 2018 manual.
Now I'm curious if it's actually something we can adjust DIY?
Old 10-23-2018, 04:19 PM   #10
atomicalex
Coming from Bosch, this Denso stuff is mindboggling to me. I'm used to just jamming the VCDS cable in and going to town. No VCDS for Subie. :sad:
www.atomicalex.com
Old 10-24-2018, 08:45 AM   #11
atomicalex
I found it and I played around with it a bit.
The dash dimmer dims the cluster, the headunit, the center stack (HVAC, clock, airbag warning), and the interior lighting sans the dome light and the door switch lighting.
My sensor is set with a 10 second delay. I think that is why I perceive it to be flaking out - it hits the ten second thing and if I am driving through an industrial park at low sun angles, the logic goes nuts.
I will dig around tonight and see if I can find anything in the manuals or in the BGB.
www.atomicalex.com
Old 10-30-2018, 12:15 PM   #12
wolffbite
Just the tip
wolffbite's Avatar
I haven't played around with this myself yet but the carista app and a bluetooth OBDII reader may be able to DIY program this. https://caristaapp.com/vehicles/subaru/brz/1st-gen
Going to try this myself to see if I can turn off some of the seatbelt dings.
The Following User Says Thank You to wolffbite For This Useful Post:
atomicalex (10-30-2018)
ambient, light, sensor
Where is the ambient temperature sensor located? solidONE Software Tuning 10 09-17-2023 02:21 PM
Oil Temperature Sensor Location g0odspeed DIY (Do-It-Yourself) Guides 4 01-30-2018 10:03 AM
Cabin temperature sensor location avg BRZ First-Gen (2012+) — General Topics 2 06-10-2017 12:06 PM
A/F Wideband O2 Sensor Bung Location FyeaFRS Engine, Exhaust, Transmission 2 06-01-2015 09:17 AM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
