Southern California SoCal
Old 09-24-2018, 04:58 PM   #1
jflogerzi
jflogerzi's Avatar
Flex Fuel Kit fail visual inspection?
As my next update I am looking at doing OFT Flex Fuel Kit. But from a visual standpoint would a flex fuel kit cause a failure for smog? I know from a header and tune perspective these would need to be returned to stock.
2013 Series 10 FRS #553
Old 09-26-2018, 04:51 PM   #2
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Instant visual failure.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
jflogerzi (09-26-2018)
Old 09-26-2018, 05:11 PM   #3
jflogerzi
jflogerzi's Avatar
Thanks for the feedback. Looking for others to chime in.
Old 09-27-2018, 02:56 PM   #4
JDMChris
Drives: 2016
INSTANT. VISUAL. FAILURE.
Old 10-01-2018, 06:59 PM   #5
Moooiiissst
The moisture is real
Moooiiissst's Avatar
Drives: '15 WR Blue BRZ Limited 6spd
I have the OFT Flex Fuel mod and I don't see a reason why you would fail the visual inspection. I'm sure you'd fail the sniff test (haven't gotten mine snogged yet), but there's nothing to add under the hood with the OFT.
If you go with Delicious Tuning kit, then yeah, you'd fail since they intercept the fuel line, but with the OFT, it's just a tune so I don't see why you would fail assuming you put the stock headers and the stock tune back in.
Someone correct me if I'm wrong with a reason as to why, please.
Sent from my SM-G935T using Tapatalk
Moooiiissst is offline   Reply With Quote
Old 10-01-2018, 09:34 PM   #6
jflogerzi
jflogerzi's Avatar
oft has a flex fuel kit just like ecutek. They used evap so you need to run a wire to the ECU..
Old 10-01-2018, 11:08 PM   #7
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
I'm just glad they're changing the smog rule to 8 years starting Jan 2019.
Decimus is offline   Reply With Quote
Old 10-01-2018, 11:36 PM   #8
Moooiiissst
Ah, I didn't know that, thanks!
Old 10-01-2018, 11:48 PM   #9
stlgrym3
Drives: 2017 Subaru BRZ Limited
That applies for any car purchased during or after 2019 or before?
stlgrym3 is offline   Reply With Quote
Old 10-02-2018, 01:54 AM   #10
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
https://leginfo.legislature.ca.gov/f...01720180AB1274
All frs/brz should be covered.
Old 10-03-2018, 12:15 AM   #11
Allch Chcar
Drives: N/A
The only way to test that is to get it smogged and see what they say.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 10-03-2018, 12:44 PM   #12
e_lunatic
Drives: 2015 Scion FR-S
just gotta find the right shop
e_lunatic is offline   Reply With Quote
Old 10-03-2018, 12:52 PM   #13
DarkSideFRS
Drives: 2013 pearl white FR-S
only new ones tho... i bought mine used
DarkSideFRS is offline   Reply With Quote
Old 10-03-2018, 02:14 PM   #14
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
Suspension - visual inspection points? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-21-2014 01:15 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
