Old 03-22-2018, 08:56 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit?
correct me if i'm wrong, getting a flex fuel tune with the actual kit i have to drain the tank all the way down before switching fuel types, whereas with the kit i don't have to worry about that. is this correct? so is a flex fuel kit an must have if to get a flex fuel tune? if so, who sells them? i know delicious tune does, who else?
stlgrym3 is offline   Reply With Quote
Old 03-22-2018, 09:09 PM   #2
coxxoc
Flex fuel tunes require a flex fuel kit so that there is a sensor emitting the ethanol percentage of the fuel. The purpose is to allow you to run gasoline or E85 or any mixture of the two. If you want to run straight E85, you only need an E85 tune. You cannot mix gasoline and E85 with an E85 only tune.
coxxoc is offline   Reply With Quote
Old 03-22-2018, 09:11 PM   #3
just_frs
Drives: 2015 Steel FR-S
To my understanding, a flex fuel tune allow you to use different level of ethanol gas without constantly changing tunes. That means it is only useful if you have a flex fuel kit that reads the ethanol content level. Without a kit a flex fuel tune it is relatively useless. It would be better to get a full e85 tune for maximum power if you want to run e85.
Sent from my SM-G925T using Tapatalk
just_frs is offline   Reply With Quote
Old 03-23-2018, 02:01 AM   #4
humfrz
I suggest you review this thread.....
http://www.ft86club.com/forums/showthread.php?t=126337
humfrz
Old 03-23-2018, 02:51 AM   #5
steve99
Sure will need flexxhardware and tune see here for morecinfo
http://www.ft86club.com/forums/showthread.php?t=120397
Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON Enalband24 Member's Car Journals 78 02-04-2020 01:55 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune tomaszjanczak Engine, Exhaust, Transmission 15 09-25-2016 11:06 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
