Drives: '17 86
Nail but no leak. Anything to worry about?
So I was rotating my tires and found a nail on one of the front tires (stock primacys) in between the treads. The nail seemed pretty small so I pulled it out and it turned out to be about a 1/3 inch deep. It still isn't leaking air.
Should I leave it and check for leaking periodically? Should I go ahead with the rotation and put it in the rear? I don't track it, but do like to take it up in the mountains. Maybe there's an obvious answer, but I'd like to hear your opinions/wisdom
#2 | |
Famous Potatoes
Drives: '15 ultramarine
Don't worry about it. No leaking, you are fine. |
Drives: 2014 BRZ Limited
Put a little soapy water on it and see if it bubbles.
not playing cards
I drove the last 15000 miles of a set of tires with a nail in one. It would leak down and trigger a warning light every week or so. Sometimes it would seat nicely and go for a few weeks.
Drives: '17 86
No bubbles coming out.
I guess I won't worry about it then. Doubt there will be a catastrophic failure driving on the street. |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Put some rubber vulcanizing liquid in the hole if not bubbling. That'll seal the deal.
not playing cards
Drives: BRZ DGM Limited
If it was my tire I would carefully pull it out and see how long it is. If it was really long or has a leak, it is an easy repair at a tire shop
#10 | |
#11 |
Drives: 2013 ARGENTO A/T
Why is there a circular scuff pattern on the tread?
I also have one with no leak. Looks dangerous but im still pushing it hard lol.
#12 |
Guessing but front tires, scuffed when turned either standing still or moving very slowly.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#13 |
#14 |
not playing cards
OP said he was rotating his tires.
| Screw / Nail in tire | kpamir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 07-03-2015 12:20 AM |
| Nail polish removal smell coming from vents. | dOMEmE | Issues | Warranty | Recalls / TSB | 8 | 09-27-2014 04:13 PM |
| Got a nail! Fixable? | jbravo373 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 09-03-2013 05:28 PM |
| Getting a BRZ tmw, worry about CEL | Sniper2606 | Engine, Exhaust, Transmission | 25 | 04-22-2013 10:28 PM |
| Nail in the sidewall | ApoNono | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 02-15-2013 07:54 PM |
