Old 09-15-2018, 05:16 PM   #1
cat94
Drives: '17 86
Nail but no leak. Anything to worry about?
So I was rotating my tires and found a nail on one of the front tires (stock primacys) in between the treads. The nail seemed pretty small so I pulled it out and it turned out to be about a 1/3 inch deep. It still isn't leaking air.
Should I leave it and check for leaking periodically? Should I go ahead with the rotation and put it in the rear? I don't track it, but do like to take it up in the mountains.
Maybe there's an obvious answer, but I'd like to hear your opinions/wisdom
cat94 is offline   Reply With Quote
Old 09-15-2018, 05:35 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Car is totalled. Part it out.
Don't worry about it. No leaking, you are fine.
Old 09-15-2018, 05:41 PM   #3
extrashaky
Drives: 2014 BRZ Limited
Put a little soapy water on it and see if it bubbles.
Old 09-15-2018, 06:15 PM   #4
I drove the last 15000 miles of a set of tires with a nail in one. It would leak down and trigger a warning light every week or so. Sometimes it would seat nicely and go for a few weeks.
Old 09-15-2018, 06:25 PM   #5
cat94
Drives: '17 86
No bubbles coming out.
I guess I won't worry about it then. Doubt there will be a catastrophic failure driving on the street.
Old 09-15-2018, 06:32 PM   #6
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 09-15-2018, 06:34 PM   #7
stevesnj
stevesnj's Avatar
Put some rubber vulcanizing liquid in the hole if not bubbling. That'll seal the deal.
Old 09-15-2018, 07:05 PM   #8
Old 09-16-2018, 08:50 AM   #9
BRZnut
Drives: BRZ DGM Limited
If it was my tire I would carefully pull it out and see how long it is. If it was really long or has a leak, it is an easy repair at a tire shop
Old 09-16-2018, 08:41 PM   #10
Apparently so would they since that is what they said in the very first post!
Old 09-20-2018, 07:31 PM   #11
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Why is there a circular scuff pattern on the tread?
I also have one with no leak. Looks dangerous but im still pushing it hard lol.
Spacemane969 is offline   Reply With Quote
Old 09-20-2018, 07:46 PM   #12
Guessing but front tires, scuffed when turned either standing still or moving very slowly.
Old 09-20-2018, 10:10 PM   #13
Oh, I believe I would replace that tire.
A person could get tetanus from that -
Old 09-20-2018, 10:47 PM   #14
OP said he was rotating his tires.
Screw / Nail in tire kpamir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-03-2015 12:20 AM
Nail polish removal smell coming from vents. dOMEmE Issues | Warranty | Recalls / TSB 8 09-27-2014 04:13 PM
Got a nail! Fixable? jbravo373 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 09-03-2013 05:28 PM
Getting a BRZ tmw, worry about CEL Sniper2606 Engine, Exhaust, Transmission 25 04-22-2013 10:28 PM
Nail in the sidewall ApoNono Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-15-2013 07:54 PM
