Old 08-26-2018, 12:51 PM   #1
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
OFT Stage 2 Tune - Check Engine Light
Does OFT Stage 2 Tune disables Check Engine Light Indication? I'm nearing 80,000 miles, and I want to make sure that I'm not missing any codes for misfires for spark plugs change.
And side question, when did you guys change your Spark Plugs?
Sent from my SM-G965U using Tapatalk
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 08-26-2018, 03:06 PM   #2
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
It did for me. And at 59k, I haven't changed mine yet.
carsebuco is offline   Reply With Quote
Old 08-26-2018, 03:56 PM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Owners manual says spark plugs at 60k
the only code that should be disabled is P0420 so your catless header doesnt throw a code.
murdoc is offline   Reply With Quote
Old 08-26-2018, 05:46 PM   #4
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
P0420 wasn’t checked off on some V4 tunes. Hopefully that’s it and all you need is rom raider.
Weigaldo is offline   Reply With Quote
Old 08-26-2018, 07:10 PM   #5
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Plugs are indeed due at 60k. Get on it, your car will thank you. Either way p0420 is the only code disabled.
MCTeeJ is offline   Reply With Quote
Old 08-26-2018, 09:26 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I think you completely misunderstood what its meant to disable or how it works.
First of all you must be running a catted or catless EL or UEL header. Second the check engine light it disables is P0420 which is an efficiency code related to being cat-less or having a hi flow cat. Thats the only CEL it disables.
Old 08-26-2018, 09:59 PM   #7
Exrald
Exrald's Avatar
Got it! I scheduled my appointment for spark plugs change. Thank you!
2013 Scion FRS
2022 Toyota GR86
Old 08-28-2018, 03:54 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You won't get a code for spark plugs. It needs to be done at 60k.
Check engine, can OFT tune help? slyder Software Tuning 15 01-23-2021 02:53 AM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
