Spun
Drives: 23' Supra
Help - Condensation/Water Drip Inside Vehicle - **VIDEO**
Video was taken on a hot day, high humidity and AC on max. Please note, the water would drip down onto the passengers left foot (approximately where the location of the drip is).
[ame]https://www.youtube.com/watch?v=GnwASrukDB0&lc=z23zsnqhzzbxyxw3yacdp43bh2d sxicrlvqtnz4ngjdw03c010c[/ame] What is this? Any tips to fix it? I don't live in a very hot climate and rarely use AC. |
#2 | |
Country Boy 4 Life
OK, I posted about this awhile back... I removed the access panel with the plug and two philips screws. I traced the shape of the panel. Then I fixed the issue by making a small gasket out of piece of rubber sheet. Once Installed, it stopped the leak. Mine was spraying the passenger!!!! I drove my car today, so I'll take pics and upload them. (when I get a break in a little while... ) EDIT: Philips screws not bolts. I also checked the drain tube.
I LIKE TIRES! Last edited by Leonardo; 08-09-2018 at 12:51 PM. |
In addition, since the water is most likely coming off the A/C condenser, the water should follow a tube/channel to the under side of the car. Most likely that tube is plugged, kinked, broken or disconnected. It should be checked and repaired.
humfrz |
#4 | |
Country Boy 4 Life
NO, My tube was totally fine. No clogs, kinks, or anything wrong with it. The panel was not sealing anymore for the water flowing behind it. Ahh, Ill go get pics now.....
I LIKE TIRES! |
Country Boy 4 Life
Here is the back of the panel. And the gasket I made to fix the leak. Which worked 100%
via Imgflip Meme Generator
I LIKE TIRES! |
#7 | |
Country Boy 4 Life
Sorry, you are right, I am overly excited to share the solution I came up with.. I also should have posted earlier that I checked my drain tube first, as it seemed the logical solution. I can tell from the video OP posted he is experiencing the exact same issue I did. The water is slightly pressurized behind the panel. Unless the panel makes a perfect seal, water will come out of that location.
I LIKE TIRES! |
Spun
Drives: 23' Supra
Seems like I could make a gasket or run some gasket maker around it..but where is the access panel?? Is there a time stamp in my video you can point out?
#9 | |
![]() I reckon I'm sort of sensitized this morning; I suggested to my daughter that she had too much perfume on - she yelled at me; I had a few items sorted wrong for the laundry - mrs humfrz yelled at me; I tried to get the toddler (in her terrible twos) to pick up some of her toys - she yelled at me. Back in the day - I would just have a bloody Mary and everything would have been OK. ![]() humfrz |
#10 | |
Country Boy 4 Life
Hello Timmy, Watch your video. You keep panning the camera up and looking right at the panel. (it has the plug with wires and two Philips screws). Try pausing it at 1 second in. Let me know if you have any more questions...
I LIKE TIRES! |
#11 | |
Country Boy 4 Life
Wow! That is a bunch of yelling!!! Hope your day goes better!
I LIKE TIRES! |
| Water Leak inside passenger side floorboard | AtlasMick | Issues | Warranty | Recalls / TSB | 30 | 03-28-2019 04:43 PM |
| Taillights with hard water spots inside | Jajanken86 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 03-31-2017 01:35 AM |
| Water leaking inside the trunk | mashal | Issues | Warranty | Recalls / TSB | 5 | 03-04-2016 10:00 PM |
| Water inside the car? | YourFearlessLeader | Issues | Warranty | Recalls / TSB | 10 | 12-16-2012 04:55 PM |
| painted tail lights now have condensation inside | sitandspin | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 11-11-2012 11:12 PM |
