Drives: Toyota GTS 86
Exhaust Manifold Absolute Pressure Sensor (EMAP)
Any of you blokes out there running one? Got any feedback on their usefulness as a tuning aid or installation pics to share?
Drives: 2017 BRZ
No experience with them, but seems like it'd be useful for fine tuning the exhaust cam timing and overlap.
Drives: Q5 + BRZ + M796
I think EGT sensors are more popular as a tuning tool. Pressure is dependent on temperature and pressure changes will change temperature too, so I could imagine a pressure sensor being usful to validate temperature data, but I have no idea if it is a useful thing for tuners to have or if tuners are even knowledgeable about how to interpret the data.
I have 1x EGT measured directly before the turbo I use as a safety for the anti-lag. "Collector' exhaust gas temp is not particularly useful in tuning though as it is an average across the 4 cylinders and then has a little time to cool.
I also have 4 extra bungs - one in each exhaust manifold directly after the head exhaust port - which get 4x EGT installed when it's being tuned on the dyno but get removed when done. You are correct in saying individual cylinder exhaust temperatures are a useful tuning aid. During the initial tuning we had one port injector not firing. The overall AFR appeared lean but with 7 of the injectors firing it was hard to know for sure, but with one exhaust gas temperature wildly different to the other three it was easy to find. I've currently got a smaller turbo installed (GTX2863) which is running out of puff for the power I want to make. I'd like to use data rather than opinion to help select my next turbo and thought the EMAP might help with turbo/housing selection. |
| The Following User Says Thank You to Hags86 For This Useful Post: | Irace86.2.0 (07-28-2018) |
#5 | |
| Atmospheric Pressure Sensor | Cal3000 | Forced Induction | 7 | 01-11-2022 11:18 AM |
| Broken Oil pressure sensor? | Dream20b | Issues | Warranty | Recalls / TSB | 38 | 01-01-2016 06:02 PM |
| Where BRZ ATM pressure sensor?? | silviahrc | Engine, Exhaust, Transmission | 3 | 12-12-2015 03:28 AM |
| Absolute cheapest way to a better sound exhaust? | Gofrs | Engine, Exhaust, Transmission | 25 | 04-24-2014 11:10 AM |
| DI pressure sensor calibration? - standalone | ElectronSpeed | Engine, Exhaust, Transmission | 0 | 02-27-2013 11:38 PM |
