Old 07-26-2018, 03:14 PM   #1
Hags86
Drives: Toyota GTS 86
Exhaust Manifold Absolute Pressure Sensor (EMAP)
Any of you blokes out there running one? Got any feedback on their usefulness as a tuning aid or installation pics to share?
Hags86 is offline   Reply With Quote
Old 07-26-2018, 04:06 PM   #2
gtengr
Drives: 2017 BRZ
No experience with them, but seems like it'd be useful for fine tuning the exhaust cam timing and overlap.
gtengr is offline   Reply With Quote
Old 07-28-2018, 02:31 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I think EGT sensors are more popular as a tuning tool. Pressure is dependent on temperature and pressure changes will change temperature too, so I could imagine a pressure sensor being usful to validate temperature data, but I have no idea if it is a useful thing for tuners to have or if tuners are even knowledgeable about how to interpret the data.
Old 07-28-2018, 04:45 PM   #4
Hags86
I have 1x EGT measured directly before the turbo I use as a safety for the anti-lag. "Collector' exhaust gas temp is not particularly useful in tuning though as it is an average across the 4 cylinders and then has a little time to cool.
I also have 4 extra bungs - one in each exhaust manifold directly after the head exhaust port - which get 4x EGT installed when it's being tuned on the dyno but get removed when done. You are correct in saying individual cylinder exhaust temperatures are a useful tuning aid. During the initial tuning we had one port injector not firing. The overall AFR appeared lean but with 7 of the injectors firing it was hard to know for sure, but with one exhaust gas temperature wildly different to the other three it was easy to find.
I've currently got a smaller turbo installed (GTX2863) which is running out of puff for the power I want to make. I'd like to use data rather than opinion to help select my next turbo and thought the EMAP might help with turbo/housing selection.
The Following User Says Thank You to Hags86 For This Useful Post:
Irace86.2.0 (07-28-2018)
Old 07-28-2018, 05:12 PM   #5
Irace86.2.0
Isn’t the data already supplied by the manufacturer—enough data? That is what the turbo compressor map is all about, right? While direct measurements might be better, and it sounds like you are a fan of going that route, shouldn’t the compressor mapping allow you to size the turbo for your application?
Atmospheric Pressure Sensor Cal3000 Forced Induction 7 01-11-2022 11:18 AM
Broken Oil pressure sensor? Dream20b Issues | Warranty | Recalls / TSB 38 01-01-2016 06:02 PM
Where BRZ ATM pressure sensor?? silviahrc Engine, Exhaust, Transmission 3 12-12-2015 03:28 AM
Absolute cheapest way to a better sound exhaust? Gofrs Engine, Exhaust, Transmission 25 04-24-2014 11:10 AM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
