Old 07-02-2018, 03:27 PM   #1
HawaiianMike
Drives: 2015 Brz Limited
Coolant Flow Direction?
Does anyone know for certain which direction does the coolant flow in our cars? Does the coolant come out of the top port of the radiator, or go into the top port of the radiator.
Ill check the temperature differences between the two to see which leaves the engine (but I'm at work and am thinking of pointless projects).
Thanks!
HawaiianMike is offline   Reply With Quote
Old 07-02-2018, 04:28 PM   #2
Icecreamtruk
Drives: Track preped NA FRS
Since the thermostat is in the lower hose side, I would imagine coolant goes into the rad there and out the top, no? Just guessing tho.
Old 07-02-2018, 09:18 PM   #3
humfrz
Well, for years now, the coolant went into the top of the radiator and came out the bottom of the radiator on most gasoline engines .. why would this one be any different?
humfrz
Tokay444 (04-11-2024)
Old 07-02-2018, 11:21 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
I can't think of a good reason. Maybe they were doing it wrong all that time.
humfrz (04-21-2024)
Old 07-02-2018, 11:59 PM   #5
humfrz
Yep, it all started back-in-my-grandfathers day. When the Ford model T came out, it had a water pump .. then, they eliminated them because they kept leaking .. then some modders put them back on .. then Ford put them back on because cars were overheating in 4th of July parades.
NOW, that we have this "boxer" type engine, that sits flat, but it is still water cooled, whereas the older flat fours were air cooled. So, since a water pump is needed (or is it?), should the water be pushed (or pulled) from one side to another or from front to rear or rear to front? Further more, if we had a radiator on each side, could we just allow natural convection to move the water through the water jackets .. thus eliminating the water pump altogether which would get rid of the water pump pulley and not requiring the mod for a lightweight pulley.
humfrz
Old 07-03-2018, 01:03 AM   #6
Ultramaroon
not playing cards
Before water-cooled two-stroke motocross engines were water-cooled head kits. They had no pump. Hot water in the top of the radiator and cold out the bottom.
They didn't work very well.
humfrz (07-03-2018)
Old 07-03-2018, 01:21 AM   #7
humfrz
Maybe they needed a bigger radiator …
We had a 1941 Ford 2 ton truck back on the farm. You could fill it with hay or grain and run it in granny gear all day long on the hottest days and it would never overheat. Why not? Because it had a radiator that was about three feet wide and about four feet tall ….
humfrz
Ultramaroon (07-03-2018)
Old 10-01-2022, 12:03 PM   #8
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Coolant flow output hose?
So, did we determine coolant flow direction?.
I recall some muscle car engines boasted “reverse flow” back in the day.
I’m wanting to install an inline sensor for water temp so must confirm which hose carry’s the blocks coolant output.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 10-01-2022, 05:44 PM   #9
Ultramaroon
not playing cards
Coolant always flows from the hot side of the thermostat through the valve plate.
^^^I'm leaving this here even though I was wrong.
Actually useful diagram
Old 10-01-2022, 05:59 PM   #10
Grady
Grady's Avatar
Why would you try to suck from the top were you can have air?
The Following 2 Users Say Thank You to Grady For This Useful Post:
Tokay444 (04-11-2024), Ultramaroon (10-02-2022)
Old 10-02-2022, 06:41 AM   #11
makinen
makinen's Avatar
Drives: Toyota 86
Name:  coolant flow diagram.png
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
The Following 5 Users Say Thank You to makinen For This Useful Post:
Compelica (10-02-2022), EndlessAzure (04-11-2024), JD001 (10-02-2022), Tokay444 (04-11-2024), Ultramaroon (10-02-2022)
Old 10-02-2022, 07:42 AM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
i'm wondering if the flow differs if the car lives in northern or southern hemispheres?
The Following 2 Users Say Thank You to JD001 For This Useful Post:
soundman98 (10-02-2022), x808drifter (10-02-2022)
Old 10-02-2022, 11:02 AM   #13
Muskoka800
Thank You All!
I’ll be installing the sensor block into the lower (larger diameter) rad hose.
Old 10-02-2022, 11:17 AM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
Better run and check all your neighbors toilets!
That was a good Simpsons episode
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
JD001 (10-02-2022), x808drifter (10-03-2022)
coolant flow
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
throttle body coolant flow direction mhiscott Forced Induction 3 07-12-2016 04:24 PM
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 03:57 AM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
