Old 06-19-2018, 08:20 PM   #1
mnguyen266
Drives: 2014 Scion FR-S Monogram
Replacing broken driver side foglight
Hi there,
I'm new to the forum, sorry if this might be asked before.
I have a 2014 Scion FR-S Monogram series. When I purchased the car it came with OEM foglights and recently my driver side foglight got busted and was wondering which aftermarket foglight is closest to OEM quality? Found out that one OEM foglight from Toyota costs around $300, not sure if I want to spend that much..
Also I plan on switching out the bulbs to match my OEM HID headlamps, any suggestions on which bulbs to use without melting the foglight housing?
mnguyen266 is offline   Reply With Quote
Old 06-20-2018, 01:37 PM   #2
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
Can't help with the housing, but once you figure that out I recommend VLEDS Micro series LED headlight bulbs. Comparable output and color to HID and much easier to install.
http://www.vleds.com/shop-products/led-headlights.html
Aipex8 is offline   Reply With Quote
Old 06-22-2018, 08:34 AM   #3
Kaotic Lazagna
Drives: GR Corolla
https://www.theretrofitsource.com/sc...ect_restrict=1
Just replacing the bulbs in the OEM housing won't really improve anything. Get those Morimoto foglights and you'll definitely see the difference.
Old 06-22-2018, 08:51 AM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You should read this
http://www.ft86club.com/forums/showthread.php?p=2825216
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (06-22-2018)
Old 06-22-2018, 09:56 AM   #5
Originally Posted by Stang70Fastback View Post
This is a startling difference and so easy to see in the GIF!
Stang70Fastback (06-22-2018)
Old 06-22-2018, 11:08 AM   #6
Stang70Fastback
A.K.A. Starlord
Yeah, I was impressed. Then again, they don't have to do much to work better than the stock setup... which is basically just a cosmetic enhancement, more than a functional one, lol.
bulb, foglight, oem
Any tips for replacing ignition coil B (driver front) hpde_addict Engine, Exhaust, Transmission 6 10-27-2017 05:23 PM
Wtb brz driver side headlight and driver side fender ikeryder13 Want-To-Buy Requests 1 10-06-2016 07:18 PM
Driver door check broken jefars Issues | Warranty | Recalls / TSB 8 06-28-2016 10:46 AM
driver side Windows cant contrl by driver side button athlon816 Issues | Warranty | Recalls / TSB 12 12-13-2014 11:06 AM
ONE (1) FRS Driver's Side LED Foglight Bezel dizzario Exterior Parts (Aero, Lighting, Etc.) 0 08-10-2014 08:07 PM
