Drives: '22 WRB
Whiteline Clunk fix
For those with a Whiteline Swaybar that clunks... You've probably read all about the endlinks and made sure those were tight, you made sure the bushings were tight, the swaybar is centered, you used washers to make sure the stud had room... And you still get a small clunk.
Tonight I looked all over and figured out what was wrong with mine at least. It was a very small clunk, more of a click/pop than anything. Turns out the 10mm bolts you take out to remove the black under tray are not all the same. A few of them have a little unthreaded ledge under the head of the bolt. Use the at the front where the two undertrays meet. If you're like me and just assumed they were all the same and threw them in a big pile, chances are you have one or two that are on the back end and are tight enough to not turn anymore but aren't really pressing the undertray to the body. There might be a tiny gap there. Fixing that fixed my noise issues. That having been said, maybe I'm the only one here dumb enough to assume all of the 10's were the same
| rear suspension clunk | Gen | Issues | Warranty | Recalls / TSB | 67 | 04-03-2015 08:52 PM |
| BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS | OAKOS Automotive | Brakes, Suspension, Chassis | 226 | 01-19-2015 01:46 PM |
| Clunk when going into first gear? | huma | BRZ First-Gen (2012+) — General Topics | 22 | 07-24-2014 05:49 PM |
| E-Brake clunk? | topazsparrow | Issues | Warranty | Recalls / TSB | 10 | 07-08-2013 11:23 PM |
| Thud/Clunk when shifting. | erom | Engine, Exhaust, Transmission | 10 | 06-17-2012 07:08 PM |
