Old 05-26-2018, 03:48 AM   #1
Brz_racer
Drives: Subaru BRZ
2018 tS steering clunk
So I just got a 2018 tS and it has 1100 miles on it and the steering wheel is making a "clunk" when I turn the wheel at slow speeds. I can also recreate the issue sitting still and turning the wheel. If i turn the wheel to the right all the way to the stop, as soon as I turn it back to the left it makes the noise. When I'm pulling out of a driveway making a right turn it also makes the noise. I can feel it slightly in the steering wheel as well when it happens. Anyone else experienced this issue? And if so what was the fix?
Brz_racer is offline   Reply With Quote
Old 05-26-2018, 04:18 PM   #2
No, but, if my car were new, I'd take it back to the dealer and ask them to sort it out and fix it.
Old 05-26-2018, 04:21 PM   #3
spike021
spike021's Avatar
Take it to the dealer and have them double-check that everything is torqued to spec, not loose, etc. Including wheels.
Had this exact same issue just last week and it's quite possible a wheel had a loose lug or two. Once everything was removed and re-torqued the issue disappeared.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 05-26-2018, 05:35 PM   #4
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Why would anyone with a new car under warranty bother posting here in an attempt to find what was wrong with their virtually new car? Toyota/Subaru don’t give you a warranty for free or because they think you’re a great guy. It’s factored in to the price you paid for your car so use it at every op you get so you get the value out of it Anything to do with steering is a MUST return to dealer ASAP situation.
Bodalenko is offline   Reply With Quote
Old 05-26-2018, 11:51 PM   #5
DANG, Bodalenko, why are you slapping around on @Brz_racer …….??
I reckon he just wants some input from the forum to possibly gain some background information before taking his car into the dealer …….
Old 05-27-2018, 03:41 PM   #6
BRZnut
Drives: BRZ DGM Limited
Ya if you go to the dealer without a clue as to what it could be, they will F up your car. Just my opinion.
Old 05-27-2018, 04:32 PM   #7
Brz_racer
Drives: Subaru BRZ
Well I'm taking it in Wednesday, when I go in I'll ask them that even if they are unable to find anything obvious, just check all the bolts and nuts and any other fastener that has to do with the steering or suspension. Almost guaranteed they will find something loose and not properly torqued. Was just looking for some input as I didn't want to walk in there cross-eyed with my **** in my hand.
Old 05-27-2018, 05:14 PM   #8
Bodalenko
Steve Bodalenko
Who here would really have a clue about a mysterious noise in the steering? Could be one of a hundred things. You just take the car straight back and say “Fix it!” You don’t need to know what’s wrong with it before you get it there. Not your responsibility. You only want to know what the did to fix it, why it needed fixing, and the likelihood of it happening again. So long as you get a copy of the service report to keep in your service book who cares. You worry about things tha go bang or squeal once you mod it or it’s out of warranty.
Old 05-27-2018, 11:14 PM   #9
highway7
Drives: FRS 2013
Not if it's under warranty
highway7 is offline   Reply With Quote
Old 05-28-2018, 12:05 AM   #10
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I worked at Toyota and we were never be able to find the cause of the clunk. 5 years down the road and the car is still fine. It just clunk from time to time.
Muaddib is offline   Reply With Quote
Old 05-28-2018, 12:15 PM   #11
Decep
Drives: 2013 FR-S Series 10
I'm betting it disappears by the time you get to the dealer, as things like this usually do. I had a nice creak in my steering when parking for 2 weeks. Took it to a Subaru shop around here and it disappeared and never returned. Maybe just getting it on the lift fixed it.
Old 05-28-2018, 06:24 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Grab a soft rubber mallet and jack the car up & start banging.
take it to dealer thou
Old 05-28-2018, 10:46 PM   #13
Reminds me of the time I bought this old GMC pickup truck from my son-in-law ……. just to have a pickup truck.
It had a heavy metal clunk/creak somewhere in the suspension. I asked Bubba how to fix it and he told me to spray the undercarriage and suspension with kerosene. I soaked (sprayed) about 2 gallons of kerosene all under that truck …… Bubba was wrong …… it still creaked loudly …..
Old 05-28-2018, 11:47 PM   #14
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
I bet it disappears too. while my '13 never exhibited such a sound within 60 k miles, the steering clunk sound i started noticing in my '16 a few weeks ago has now disappeared.. though now that i think about it, i do have lowering springs whereas i kept the stock ride height on the first frs..not sure if it could be related to that
HKz is offline   Reply With Quote
Clunk noise when turning steering wheel to right noonedoesnt Issues | Warranty | Recalls / TSB 15 07-03-2018 09:14 PM
Thrust/pillowball mount bearing clunk while steering VacantSky Issues | Warranty | Recalls / TSB 14 06-04-2015 12:43 PM
Steering clunk over rough roads 73TORANA! Issues | Warranty | Recalls / TSB 39 12-05-2014 07:52 PM
Whiteline Clunk fix trippinbillies40 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-26-2013 05:44 PM
E-Brake clunk? topazsparrow Issues | Warranty | Recalls / TSB 10 07-08-2013 11:23 PM
