Old 05-07-2018, 03:36 PM   #1
AP756
Drives: GT86 Toyota
The same problem again (2014 reborn)
Tried to load the V4 files to my OFT. Got the same error message as shown in this old topic http://www.ft86club.com/forums/showthread.php?t=74170 under issue "4" but for any file I try to transfer. Tried 3 different computers and installed OFM at least 5 times to no availability. I'm stuck and hope someone can help me.
@shiv: Was this a Server problem back in 2014 and can you have a look into this?
Greetings from Germany
AP756 is offline   Reply With Quote
Old 05-08-2018, 02:20 AM   #2
nofferman
nofferman's Avatar
I had this problem (the DEV121.dll error) as well this week. I tried four different PCs and got that error on all of them.
My OFT firmware hadn't been updated in a few years, which I think was part of the problem. OFM showed HW Version 1.0/FW Version 1.24, while my OFT display showed HW 1.35/FW1.55.
The fix for me was to flash the stock map into my ECU, erase the tablet using OFM, re-read the stock map, then upload v4 maps. No more errors, was able to flash the car.
After I wiped it, the HW/FW version numbers all showed 1.35/1.55.
Good luck!
nofferman is offline   Reply With Quote
Old 05-08-2018, 03:24 PM   #3
AP756
Drives: GT86 Toyota
More detailed info:
OFT Info
- Sn: E00401002073D054
- Cd: P9029
- HW Ver: 100
- Fw Ver: 127
Computer Info
- OS: Win 7, Win 10 home, Win10 pro
ECU Info
- ECU Type: DENSO GT86
- CAL: ZA1JA00G
Trying to write any tuning file to the tablet I get a window titled Cktrl, and it has the message "C:\OpenFlash\DLL\DEV121.DLL". When I hit OK, I get another window titled Cktrl and it has the message "1". When I hit OK, I get a window titled OpenFlash Manager and it states "The checksum of file Stg 1 v4.03 LC FSS ZA1JA00G is wrong".
At present I run Stg1 A00G 2076.bin in Slot1, I was able to free Slot2 but I cannot upload any file.
In the process to connect Open Flash manager updated to v1.32.0 (on all computers) and now shows HW 01.35 / SW 01.51
Can't try your suggestion right now @nofferman, I'm on a trip for the next five days. Coming back hopefully I got enough info to make my tablet working correctly again. TIA for all help.
Bye for now Fred (AP756)
Edit: @nofferman: Thought about my problem a few minutes again and decided to try your suggestion right now (doing a 1000km trip tomorrow would be a good chance to test the new tuning file...). Reflashed stock tuning file to my car, back to the computer I ereased all data, back to the car I re-read the original tuning, back to the computer and some update later (it's done automatically) I tried to copy "Stg 1 v4.03 LC FSS ZA1JA00G" to the tablet (no more problem), back to my car I flashed that file successfully. First run showed no problem, will monitor that tomorrow on the run. Thank you for that suggestion, problem solved (for me ). Now I can go to sleep with a smile on my face
Old 05-21-2018, 12:30 AM   #4
commandar
Confirming the same issue and resolution for me. DEV121.dll error no matter what tuning file I tried to add to the tablet. Flashing to original tune, wiping the tablet, and rereading fixed it.
I was already on a v4 tune flashed a few weeks ago, so I don't know that flashing from an old version is necessarily the cause. I was just looking to update my IAM value. I did just get a new PC, however, and had to set OFM back up immediately before this.
commandar is offline   Reply With Quote
Old 07-07-2018, 12:36 PM   #5
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
having the same problem, unable to upload on my tablet any tunes.... is there a solution?
Walla Walla is offline   Reply With Quote
Old 07-07-2018, 11:23 PM   #6
Walla Walla
Hicas Thread Basher
i was able to fix this by installing an old version (1.10) and update it... now it works
Old 07-08-2018, 05:21 AM   #7
elBarto
elBarto's Avatar
Drives: Toyota GT86
Could you upload that version?
I have the Dev121 problem as well.
OFT was working fine. Reinstalled Windows and after that I had the problem and whichever pc I use, the problem is stays.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 07-09-2018, 05:12 PM   #8
AP756
Drives: GT86 Toyota
Please follow the instructions in post #2 (last block named edit). This procedure works, bye for now Fred (AP756)
FFXIV A Realm Reborn SP86 Off-Topic Lounge [WARNING: NO POLITICS] 32 02-15-2021 11:48 AM
2014 86CUP presented by Winmax #4 -Chuckwalla Valley Raceway - Apr 5, 2014 (Saturday) CSG Mike Tracking / Autocross / HPDE / Drifting 128 04-16-2014 11:33 PM
2014 Scion Display Audio problem Bach415 Electronics | Audio | NAV | Infotainment 2 03-22-2014 11:29 PM
2014 1st ANNUAL CENTRAL FLORIDA SUBARU MEGA MEET & GREET 2/15/2014 Opie Southeast 1 02-10-2014 04:24 PM
2014 Bespoke w/ Aha problem gatorbushmen Electronics | Audio | NAV | Infotainment 25 11-26-2013 10:55 PM
