Old 11-26-2013, 12:31 AM   #1
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
2014 Bespoke w/ Aha problem
So I installed my new head unit with nav extension box and everything works beautifully except for the fact that the USB port charger does not work. I checked for secure connections on the back of the head unit and everything was snug. Im stumped!!
Any ideas?
gatorbushmen is offline   Reply With Quote
Old 11-26-2013, 12:51 AM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Any ideas?
at least i know it's not just me now. does it work for even usb or totally dead?
lbroskee is offline   Reply With Quote
Old 11-26-2013, 01:02 AM   #3
gatorbushmen
Amateur Drifter
Drives: '13 FRS
totally dead.... haha :/
Old 11-26-2013, 01:04 AM   #4
lbroskee
lbroskee's Avatar
did u get yours from super duty too?
Old 11-26-2013, 01:08 AM   #5
gatorbushmen
Amateur Drifter
Drives: '13 FRS
I came from the base stereo, and after some quick research, i found out that the base unit uses "USB 2.0 full speed" while the new head unit uses "USB 2.0 high speed"..... after a quick google, full speed nets 12 mb/s while high speed is 480 mb/s....
Now I just looked up the USB specifications for the 2013 Bespoke and it is USB 2.0 High speed. So I am assuming those who have upgraded from the base stereo are the ones having this problem?
Old 11-26-2013, 01:09 AM   #6
gatorbushmen
Amateur Drifter
Drives: '13 FRS
yes sir! did you have the pioneer base unit before?
Old 11-26-2013, 01:10 AM   #7
lbroskee
lbroskee's Avatar
i've had all 3 head units and the 2014 is the only 1 that doesn't let me use my USB though so that can't b it. it's gotta be a 2014 exclusive issue
Old 11-26-2013, 01:16 AM   #8
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Are you even able to use Aha?
Old 11-26-2013, 01:18 AM   #9
lbroskee
lbroskee's Avatar
nope. according to the manual, u have to b USB connected to use it with an iPhone. where did u connect the gray plug in the back? up top lil old units or bottom?
Old 11-26-2013, 01:22 AM   #10
gatorbushmen
Amateur Drifter
Drives: '13 FRS
Im on a 4s.... are you on 5? and i connected the square gray plug in the only spot that it would fit.
Old 11-26-2013, 01:26 AM   #11
lbroskee
lbroskee's Avatar
I'm on a 5S
and it fits in both of these actually. idk what the difference is tho
Old 11-26-2013, 01:29 AM   #12
gatorbushmen
Amateur Drifter
Drives: '13 FRS
I'm on a 5S
oh okay gotcha. where are you plugged up to?
Old 11-26-2013, 01:30 AM   #13
lbroskee
lbroskee's Avatar
at the moment the top one. what about you? if ur in top also ill see if thats the issue in the AM
Old 11-26-2013, 01:32 AM   #14
gatorbushmen
Amateur Drifter
Drives: '13 FRS
yep I'm top one as well. i bet you that's the problem. Im gonna go try it now, haha.
2014 bespoke headunit with aha questions?? 86black Electronics | Audio | NAV | Infotainment 8 09-02-2014 12:08 PM
Bespoke (2013 or 2014) Tman08 Want-To-Buy Requests 4 12-02-2013 03:08 AM
Bespoke problem with connecting sweetfrs Electronics | Audio | NAV | Infotainment 1 04-24-2013 01:01 PM
FR-S Bespoke Contact List Transfer Problem Wayne Electronics | Audio | NAV | Infotainment 5 02-14-2013 01:08 AM
Video Connection Bespoke Problem. dale.m Electronics | Audio | NAV | Infotainment 6 02-10-2013 07:54 AM
