Drives: GT86
Hi
Give a look to this Maintenance Schedule from Toyota Europe https://www.toyota-tech.eu/MS/PDFS/7...05e8669332.pdf What do you think? |
Only users lose drugs.
Drives: All the time
That's not a schedule specifically for the FRS/BRZ/GT86, but just Subarus in general since there's reference to engine oils for turbo motors, front differentials, etc.. As such, the transmission oils cover both transaxle (GL5 rating to cover hypoid gears), as well as our transmissions (LV Gear oil API GL-4)
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Drives: 2015 BRZ Limited
I'm using 0w40 mobil one euro spec. The car makes more noise at cold starts, and seems to take a bit longer to bring the oil temps up. However, the oil and water temps stay right around 192 F during normal driving. For spirited driving oil temps are between 220-240 F, but come back down a lot quicker when cruising.
20w50 seems really thick, so unless you live in an area with a really warm climate or humidity, you probably don't want to run something that thick unless the motor is running a turbo or supercharger.
#4 | |
Drives: GT86
#5 | |
I see what you mean, but that would be a huge contradiction to the North American literature, as well as what Toyota USA themselves claim is the appropriate oil to use when replacing the factory fill. It's far more than just the difference between 10W-30 versus 10W-40; going from GL3/4 to GL5 is closer to gas versus diesel. GL3/4 is compatible with yellow metals; GL5 is NOT.
#6 | |
Drives: GT86
Anyway, the owner's manual says the same thing in Europe 0w-20 and API GL-3. It was amazing for me that's why I shared it. |
| The Following User Says Thank You to NordicGT86 For This Useful Post: | venturaII (04-19-2018) |
| Shifting Clunk/Pop - AT Tranmission Issue | TofuJoe | Issues | Warranty | Recalls / TSB | 5 | 05-29-2017 01:29 PM |
| Tranmission Bolts | gl2filmerguy | Engine, Exhaust, Transmission | 2 | 06-05-2016 01:31 AM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 07:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 07:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
