Old 04-15-2018, 03:50 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
Endlink bolt issue
So I am currently installing some new coilovers. The endlink bolt is seized and the hex is pretty much stripped.
Any ideas? Cut? Or remove bolt that connects to the sway bar (is that the same hex issue)
Thanks
oppiee is offline   Reply With Quote
Old 04-15-2018, 03:59 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The bolt is actually a stud that is part of the end link. If the hex is already stripped just drill it out. If you have anymore to remove, I recommend heating the nut a little before attempting to remove.
Old 04-15-2018, 04:11 PM   #3
oppiee
Well I actually started turning the nut. But its now stuck. I assume if i decide t saw off the stud I need a new endlink or can i replace the stud?
Old 04-15-2018, 04:17 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You will need to replace it, so cut away. If it is still tight enough to not spin, I prefer to drill out the center. It is more manageable to do without risking damaging other parts.
You might as well get some adjustable endlinks, sometimes with a lowered car the factory ones will rub the control arm.
Old 04-15-2018, 09:24 PM   #5
wparsons
wparsons's Avatar
If they've been on the car for longer than a couple years you'll probably have to cut them off unless you got really lucky. If you ever have to do it again, you can try to soak them with PB Blaster or WD40 first and wire brush the threads.
flickr
SPC Camber Bolt Issue breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-20-2021 09:22 AM
SPC Camber bolt install issue AnotherDude000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-10-2017 05:59 PM
TRD Quickshifter Issue with Adapter Bolt (USDM Version) switchlanez Engine, Exhaust, Transmission 2 01-25-2017 08:55 PM
Safe to drive with 17mm endlink/strut bolt not fully tight? kev60625 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-17-2016 03:23 AM
Aftermarket endlink advantages Kai Uhl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-03-2013 07:22 PM
