Old 03-22-2018, 07:54 PM   #1
sid94
Drives: 2013 frs
High pressure fuel pump resistance?
Hey all
I have been fighting a fuel pressure issue and I have been trying to get a local to bring by their car so I can check their pump but no luck so far
In my data log high side rail pressure is at around .65megapascals when target pressure is 4mpa which translates to 95psi when I should be at around 580psi.
I was looking up on the service manual and checking the specs of the pumps resistance that the pump should have with the connector off
So my resistance should be at .45 - .55 ohms with connector off and I’m getting 1.7-1.9 ohms before I go and buy said expensive pump I wanted to see if anyone can verify this anyone with a known good pump laying around or anyone who would so kindly take injector cover off and check the resistance of their pump with the connector off to verify it.
Thank you for your time!!
sid94 is offline   Reply With Quote
High Pressure Fuel Pump and Aftermarket Headers NRXRaptor Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 03-28-2021 03:23 PM
So chirping noise from high pressure fuel pump Nefarious Issues | Warranty | Recalls / TSB 19 03-12-2017 10:49 PM
high pressure fuel pump = 5 years / 100 000 km ? jefars Issues | Warranty | Recalls / TSB 7 09-16-2016 01:26 PM
High Pressure Fuel Pump Thread crazyfrenchbiker Engine, Exhaust, Transmission 10 09-09-2015 01:32 AM
High Pressure Fuel Pump Difference? Toyota vs. Subaru 86_ZN6 Engine, Exhaust, Transmission 18 06-03-2013 06:48 AM
