Old 09-07-2015, 09:31 AM   #1
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
High Pressure Fuel Pump Thread
Anyone happen to know what the thread pitch is for the banjo fitting that connections from the driver fuel rail into the high pressure fuel pump?
crazyfrenchbiker is offline   Reply With Quote
Old 09-07-2015, 10:20 AM   #2
aagun
Drives: 86
if removeed . scratchs or any damages . replace it with now one
aagun is offline   Reply With Quote
Old 09-08-2015, 08:49 AM   #3
crazyfrenchbiker
Hot Lava 6MT
With the amount of pressure involved in the pump, I can certainly appreciate that. This fitting is feeding the HPFP, so it should be dealing with relatively low pressures (50-60psi).
I do appreciate the advice, I'm looking to switch it to an AN line.
Old 09-08-2015, 09:31 AM   #4
fika84
fika84's Avatar
What makes you think it's low pressure, if it's dealing with the high pressure fuel pump?
fika84 is offline   Reply With Quote
Old 09-08-2015, 10:02 AM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
[...]This fitting is feeding the HPFP, so it should be dealing with relatively low pressures (50-60psi).
jawn is offline   Reply With Quote
Old 09-08-2015, 04:51 PM   #6
aagun
Drives: 86
i think no buddy remove these fitting and will will be the first one do it
Old 09-08-2015, 06:08 PM   #7
crazyfrenchbiker
Hot Lava 6MT
Of course, I mean relative to what is output on the pressurized side of the HPFP where we are talking about pressure in the thousands.
Old 09-08-2015, 06:09 PM   #8
crazyfrenchbiker
Hot Lava 6MT
Thanks for your help. I've seen it done on a single race car that I helped work with. If only we could find the eBay auction it was purchased from so we can order more...
Old 09-08-2015, 06:52 PM   #9
It's been done.... but I don't know the size, which doesn't help anyone
Old 09-09-2015, 01:22 AM   #10
aagun
Drives: 86
i remember that Full Blown 700hp did it too ><
Old 09-09-2015, 01:32 AM   #11
aagun
Drives: 86
the good deal is keep DI fuel feed line stock and the same fuel delivery pipe and that connect it to new PI fuel rail unless you donna full boost ur engine then you need alot of fuel that u have to change alot of parts to make ur engine happy with it .
what u need it stock 3 bar fuel rail to keep DI system works . fuel pump to in tank fuel regulator 3 bar to two feed lines (one for DI and one for PI) ans there is no returned line .
good luck
frs low fuel rail pressure ? 15,000 miles j0hnnybk01 Issues | Warranty | Recalls / TSB 10 03-04-2014 03:03 PM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 02:40 PM
High Pressure Fuel Pump Difference? Toyota vs. Subaru 86_ZN6 Engine, Exhaust, Transmission 18 06-03-2013 06:48 AM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
