| Engine Swaps Discussion of engine swaps. |
Drives: Supercharged GT86
Cable throttle
Anyone fitted an engine which uses a cable throttle rather than FBW?
What are the options when it comes to this? Change the pedal to a cable connection? Convert the OEM pedal to a cable connection? Replace the TB for a FBW alternative? Cheers |
FBW is the easiest.
Huge E85 fan!
Drives: 2016 Scion FRS
Cars don't work like that anymore. You can't just wire up a throttle wire. There's a whole lot of stuff going on when you hit the gas pedal and the days of directly opertaing the throttle are long gone
Drives: 14 BSP Edelbrock BRZ
How big of a pilot valve are you running?
#7 | |
As above, hoping we can use the Motec ECU to keep a FBW setup and just stick a new TB on the intake and incorporate it into the engine loom we're making |
I meant pilot jet. If you are going to go to a wire throttle I assumed you were into retro chic or steampunk and you would be using a carburetor.
I'm going to go out on a pretty substantial limb and say the motec is expecting to be controlling the throttle FBW... |
#9 | |
Thanks for confirming |
#10 |
Yes that will work.
#11 | |
Drives: UK GT86
https://www.google.co.uk/search?q=se...hrome&ie=UTF-8 You could use any electronic throttle body that's the right size, the wiring is different depending on make but if you're custom wiring it anyway then it makes it easy to pick based on requirements and budget. This also gives you a better selection than cabled systems.
.: Stealth 86 :.
#12 |
Drives: LS Swapped Scion FRS = 440HP
Reviving this thread.
I'm currently starting the parts gathering to swap my LS from my 1971 240z over to my FRS. Its a cable driven throttle body with stand alone harness megasquirt ECU. Looking at the firewall around the throttle pedal, it seems cramped. Has anyone done this? I've seen photos of some element tuning car with a cable throttle in it. But I cant seem to find much info or parts necessary. |
#13 |
Drives: 2015 FRS - FFR GTM
What will become of the 240z??
2015 FR-S - One Day I'll Finish The Swap |
#14 |
Selling it http://forums.hybridz.org/topic/1288...ing-car-parts/
I've got about six or seven people interested in it right now, next person is looking at it this upcoming tuesday. Hoping it sells soon, it'll be funding the parts for the FRS LS swap. |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
| Throttle by cable FA20? | MicahG6 | BRZ First-Gen (2012+) — General Topics | 21 | 10-09-2017 12:46 PM |
| Gauge install, dash cluster light cable, Tach RPM cable help... | Sportsguy83 | Electronics | Audio | NAV | Infotainment | 99 | 08-07-2016 10:36 PM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 12:44 PM |
