Old 02-12-2013, 05:10 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Gauge install, dash cluster light cable, Tach RPM cable help...
Fellow electricity enthusiast, I need help. I have looked at the wiring manual and while I have a general idea about it, I really don't understand everything on it.
I will be installing gauges soon and need to tap my gauges to the cluster lights cable in order to have the gauges dim accordingly. Could some help me figure out which cable I should be tapping into? What about the RPM Tach cable?
While we are here, can I can I crimp the power cables for both gauges together and add them to a single "add a fuse"? Each gauge requires 5A Fuse, so I figured I can use a 10 Amp fuse. Those that make sense or I need to add a separate "add a fuse" for each?
Thanks in advance!
Old 02-12-2013, 07:43 AM   #2
2forme
Ever think about using the radio dimmer signal wire?
Old 02-12-2013, 08:05 AM   #3
Sportsguy83
Drives: Limited BRZ
Well, it might work but I'm not sure. I don't know how the circuit within the gauge works. Does it take the signal to turn the cluster lights on to dim the gauge display? And also, how does the radio dimmer work, does it send a signal to dim it or is it actually grading the amount of current down to dim it? I honestly don't know the answer to either but maybe you know more than me and can answer them.
Or maybe you just know using the radio dimmer just works for gauges?
Thanks for the help! Let me know what you think.
Sent from my HTC One X using Tapatalk 2
Old 02-12-2013, 11:06 AM   #4
2forme
Well, the gauges that I have in my other car just run full brightness, until the dimmer wire gets juice. I have it piped into my radio harness to handle that....
I guess it depends on the gauge, what do the installation instructions say?
Old 02-12-2013, 05:10 PM   #5
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Not sure if its exactly what youre looking for, but i wired in some LED's into my air vents using the radio dimmer and they work like a charm. They are off until i turn the lights on.
Trashed675 is offline   Reply With Quote
Old 02-12-2013, 06:11 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks in advance!
Mine just illuminate with the illum feed, no dimming. Damn expensive Defi's can't do that unless you go to the newer Advance BF ones.
I pull my feed off the foglight fuse so I can turn off the annoying gauge illumination at night The warning light is enough in case there's an issue.
For the fuse, run whatever the load should be. I doubt the gauge really pulls that much. Since mine is control unit based I just needed one feed. In the race car I have them all fed off one power wire with a 5A fuse for 3 autometer gauges. Illumination is pulled off the radio illumination wire.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 06:30 PM   #7
Sportsguy83
Drives: Limited BRZ
Look at page 3 here: http://www.aemelectronics.com/Images...%2030-4900.pdf
I guess it does work like you say, they run full brightness until the instrument panel cable gets juice. So then, what is the cable for radio dimmer? Thanks for the help!
I honestly don't know exactly if they Dimm or not, I guess I'll figure it out when I install them. Waiting for the Prime Motoring Cluster. Thanks for the help.
Old 02-12-2013, 07:47 PM   #8
Sportsguy83
Drives: Limited BRZ
Have any idea on what is the RPM cable in the cluster harness?
Old 02-12-2013, 08:33 PM   #9
OrbitalEllipses
Drives: Attitude
Subarus usually have reversed illumination circuits. Personally hate wiring, so I haven't explored this further, but it's on every major Subaru forum for your digestion. Big ole scar from the soldering iron was enough.
Old 02-12-2013, 09:20 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have the dimmer wire hooked up properly to my AEM gauge which allows the dimmer circuit to be either 0 to 12v or 12 to 0v. Unfortunetly, the difference in V between dim and not dim is not enough to change the gauge. I would recommend just leaving that wire unhooked. As for RPM, there are a couple wires that you can use:
Pin 17 on connector D48 Gray Wire
Pin 15 on connector A35 Gray/Red Wire
I haven't gotten around to trying either of these yet though.
Old 02-12-2013, 11:54 PM   #11
Sportsguy83
Drives: Limited BRZ
That sucks... do you feel they bother much at night? (Thanks for the RPM signal location)
Old 02-13-2013, 12:17 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Well my gauge just has the not very bright LED screen in the middle since it only shows black and the white number of my boost or vacuum and the lights on the outside for the air fuel ratio, no backlight, so I think it is fine in full bright mode. I can move the dimmer switch and get the gauge to temporarily change to a dimmer mode, but then it comes right back to full brightness shortly afterwards which is weird. I checked the voltage and it definitely changes on that wire when you move the dimmer switch from full bright to no bright.
Old 02-13-2013, 12:21 AM   #13
Sportsguy83
Drives: Limited BRZ
I bought the failsafe so this is great info. The other gauge is Oil Temp same series as the failsafe.
Old 02-13-2013, 01:32 AM   #14
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Thanks in advance!
I'm an electrical engineer and self-proclaimed wiring guru. I've been doing automotive wiring since I was 16 and for the last 10 years. I'd be glad to help if you still need it.
Can you first provide a link or make and model of the exact gauge(s) you purchased?
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
dash, gauge, gaugle cluster, pod
What is that blinking dash light when the car is off? JayNutter Scion FR-S / Toyota 86 GT86 General Forum 7 02-03-2014 10:59 AM
WTB: FRS instrument cluster jabbajaw99 Interior Parts (Incl. Lighting) 3 02-14-2013 01:31 PM
surprised at how much MORE i like the frs dash cluster pr086 Scion FR-S / Toyota 86 GT86 General Forum 26 12-07-2012 09:09 PM
Flashing Security Light in Dash? ravenMTgirl Electronics | Audio | NAV | Infotainment 8 11-21-2012 03:25 PM
Scratches on my Cluster. Superhatch BRZ First-Gen (2012+) — General Topics 5 08-21-2012 07:50 AM
