Old 03-08-2018, 05:09 PM   #1
arkanist
Drives: 2016 BRZ Limited, Stock
Help with suspension issue
Hey ya'll, I'm having a few issues with my suspension and am trying to diagnose the issue.
A while back I dropped my front driver side wheel off a curb at ~25mph bad enough to mess up my alignment and to cock the wheel 20-30 degrees to the right. I got new wheels and tires and an alignment and everything was fine for a while.
Fast forward 6-7 months and I started noticing that while backing out of my garage and turning left (full lock) I would sometimes hear a clunk. This clunk has been getting louder and now is to the point where I feel the car lurch a little when it happens. Also, the front driver side of the car has started making a quiet creak when going over speed bumps.
I am going to put her up on stands and try to take a look tonight but was curious if anyone could identify the issue from that information.
arkanist is offline   Reply With Quote
Old 03-08-2018, 05:17 PM   #2
HimBRZ
HimBRZ's Avatar
Drives: 2013 BRZ Limited
I know this may sound overly simplistic, but I think something is loose.
HimBRZ is offline   Reply With Quote
The Following User Says Thank You to HimBRZ For This Useful Post:
arkanist (03-08-2018)
Old 03-08-2018, 05:51 PM   #3
arkanist
That would be great. I will check everything over when I get it on stands tonight. Thanks!
Old 03-08-2018, 06:17 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Check your upper ball joints. They made a clunk noise on my lexus when one of mine started to go out. If it is this issue, fix it right away.
I LIKE TIRES!
Old 03-08-2018, 06:17 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Could possibly be a leaking strut causing the creak when you go over speedbumps.
tyler_win_photo is offline   Reply With Quote
Old 03-08-2018, 06:29 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Also be sure to check the strut braces the go to the firewall. They can clunk when the chassis shifts as well.
Use a wrench to check everything. Things can seem tight by hand but really be fairly loose still
Old 04-06-2018, 05:59 PM   #7
arkanist
Late update but an update none the less.
Crash bolts were loose. Ball joint was loose (that was the clunking). Tie rod was bent. Strut was bent.
Everything but the strut is fixed and I am picking up / installing a pair of oem front coils tonight. Should be back to 100%.
Clearly I should have had this looked at sooner.
The Following User Says Thank You to arkanist For This Useful Post:
strat61caster (04-07-2018)
Suspension issue? Dacfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 12-08-2017 09:25 PM
Need Help with Suspension Issue Silverfox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-04-2017 12:44 PM
Tein Street Flex suspension issue (lowering itself over time) Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 64 07-26-2015 05:00 PM
Suspension Question/Issue slmducf20 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-04-2015 10:45 PM
Need help fast - suspension issue during spring install finch1750 Scion FR-S / Toyota 86 GT86 General Forum 5 07-08-2013 03:30 PM
