Old 07-21-2015, 07:57 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Tein Street Flex suspension issue (lowering itself over time)
I have an issue with my suspension. I've had it installed for 6 months. Twice already (let's say 3 month interval between checks), the suspension has lowered itself.
I have tightened the lower ring with all the force I could, having friends help. I've held the two upper rings with the other spanner wrench to tighten the lower ring even more without them moving.
It seems simple enough, and I don't see anyone else having that problem. It happens on both fronts.
Help???
@CSG Mike @Racecomp Engineering
Old 07-21-2015, 08:02 PM   #2
Bergen23
Drives: '15 Halo FR-S
You using a flathead screwdriver and a hammer to tighten down the lower collar? That could be your problem.
Edit: could be your problem if you aren't using that method to tighten
Bergen23 is offline   Reply With Quote
Old 07-21-2015, 08:07 PM   #3
Sportsguy83
Drives: Limited BRZ
I did the second time, still happened. The lower collar itself was super tight and almost impossible to get it off today, but that did not prevent the suspension from lowering itself all the way to the bottom.
Old 07-21-2015, 08:18 PM   #4
Bergen23
Interesting. Only other thing I could think of it being is the top collars then. Is your preload set correctly? I know that seems obvious too, but I know for me, the solution is more often than not in the blindingly simple/obvious thing.
Either way, I'll be watching this thread to see what the problem ends up being. Good luck with finding the cause.
Old 07-21-2015, 08:22 PM   #5
8R6
8R6's Avatar
Drives: FRS
take them off and just sell it to some stance guy and say "it just keeps going lower and lower by itself!"
guaranteed sale.
8R6 is offline   Reply With Quote
Old 07-21-2015, 08:26 PM   #6
Sportsguy83
Drives: Limited BRZ
I have never moved the preload, as they are supposed to come where they should be from stock, and should not be moved unless you want to tinker with them...
I hope someone of the suspension experts can come in with an easy problem/solution.
Thanks a lot for your ideas!
Old 07-21-2015, 08:46 PM   #7
Are the rings clean?
Old 07-21-2015, 08:48 PM   #8
Streetthrowback
Drives: 2015 brz
Subb
Streetthrowback is offline   Reply With Quote
Old 07-21-2015, 08:58 PM   #9
Sportsguy83
Drives: Limited BRZ
Not super clean but not particularly dirty. The car has seen rain maybe three times on the six months. I do feel dirt in between the bottom ring washer and the bottom mount. So clean them up good in the contact surfaces?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 07-21-2015, 09:03 PM   #10
Just to be safe.
Also, get a paint pen, and draw a line that goes over the threads, over the rings, and onto the threads on the other side, so you can get a visual reference of if and how much they move.
Old 07-21-2015, 09:07 PM   #11
Sportsguy83
Drives: Limited BRZ
Just to be safe.
Thanks a lot Mike. I'll do that!
Also tighten them as much as possible and use the flathead to tighten more?
Old 07-21-2015, 09:09 PM   #12
Streetthrowback
Drives: 2015 brz
You shouldn't be using that, you should be using the keys it came with, if you lost them buy a set their cheap
Old 07-21-2015, 09:16 PM   #13
Bergen23
Except for the fact that companies such as Fortune Auto recommend this to be done when installing.
Old 07-21-2015, 09:16 PM   #14
I would say nice and firm. You don't want to damage them. Use the provided tools; putting your weight on it should be plenty tight.
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 11:04 AM
Tein Street Flex installation Help eguzman6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-08-2015 03:08 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 12:40 AM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
