Old 07-08-2013, 03:15 PM   #1
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Need help fast - suspension issue during spring install
OK. As I was installing springs last night I ran into a problem fighting to get things to line up. Long story short, in the end I essentially disassembled the entire rear assembly and put it back together. Now I am having issues with the a-arm bolting back to the hub. I never seperated these, but did take the bolt out trying to getmore play. Now the joint is twisted and the bolt won't go back in the hole (pics below). I'm kinda lost at this point and have been at this since last night.
Old 07-08-2013, 03:20 PM   #2
SpyderDan
Toyota hoarder
SpyderDan's Avatar
Drives: 10 Series FR-S, 05 xB, MR-S GT-300
I ran into similar trouble doing mine on Friday. I had the car up on jack stands, and I needed to get a floor jack under the lower control arm and lift it a bit, and used a crow-bar to leverage the angle of the control arm to get it to line up. It was the only tough part of the install, and required a bit of muscle and maneuvering.
SpyderDan is offline   Reply With Quote
Old 07-08-2013, 03:21 PM   #3
finch1750
finch1750's Avatar
Another view
Old 07-08-2013, 03:25 PM   #4
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
ihaskrayon is offline   Reply With Quote
Old 07-08-2013, 03:27 PM   #5
finch1750
finch1750's Avatar
I'm trying hammer and prybar. At this point should I just seperate the a-arm from the hub? I can't figure out any other way to rotate it
Old 07-08-2013, 03:30 PM   #6
Darrellbuddy321
Drives: Fr-s
pmd
Darrellbuddy321 is offline   Reply With Quote
Blown strut or other problem after spring install? f0rge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-12-2016 03:26 PM
Spring install DaBrz Northwest 8 05-14-2013 10:47 AM
East bay shops for spring install? WillBRZ Northern California 9 02-21-2013 02:03 AM
KW suspension Spring flip thought process jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 01-22-2013 11:58 PM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
