Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 04-15-2016, 09:27 AM   #1
ZZT86
ZZT86's Avatar
Drives: BR86
Alignment Recommendation
Curious to hear what you guys would recommend for my BR86. It's a DD which does 60% fwy & a spirited drive a few times a year, no tracking, car as follows:
18x8.5+42 with 225/40 tyre, Eibach ProKit so about 18mm drop, front SPC camber bolts & rear SPC LCA. What sort of alignment would you dial in ?
Cheers
edit: actually once off the fwy I like to utilise the car's turning prowess at any given opportunity so I would more often than not be cornering faster than most - it is after-all a sports car but it still gets driven quite sedately compared to others
ZZT86 is offline   Reply With Quote
Old 04-17-2016, 12:06 AM   #2
Ashikabi
Ashikabi's Avatar
I'm not sure what stock numbers are but I'd think something like -1.5 front and -.5 rear for camber would be good. Stock toe and caster
The Following User Says Thank You to Ashikabi For This Useful Post:
ZZT86 (04-18-2016)
Old 04-17-2016, 01:30 AM   #3
steve99
In Australia try talking to these guys
http://mcasuspension.com/
guy by the name of josh coote who works their does sprints etc with 86 , sure he would give you some spec's
Old 04-18-2016, 07:46 AM   #4
ZZT86
ZZT86's Avatar
Drives: BR86
Thanks Steve. I have spoken to Josh a few times re a set of blues a while ago then decided against coilovers & just swapped the springs. Josh is amazingly helpful although I'm not sure he would give me some numbers for a virtually stock setup that's only marginally lower & doesn't involve any of their product.
I'm thinking -1.5F & -1R camber each side, zero toe F & about 1-1.5mm toe-in @ the rear, so essentially a stock setup except for the negative camber of which there is more up front for improved turn-in feel. Can you remember the #'s on your car ?
Old 04-18-2016, 06:40 PM   #5
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I just take mine to my suspension guys (True Track) and they work their magic.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 04-19-2016, 05:14 AM   #6
ZZT86
ZZT86's Avatar
Drives: BR86
@fuddbutter - yep I recall you recommending them in the past. What they charge you for wheel alignment ? How is your car setup ?
Old 04-19-2016, 07:07 AM   #7
steve99
Stock number then just -1 deg front camber( with whiline camber bolts), i dont have rear lca so no camber adj at rear for me, im on sti pink springs so only 15 mm lower than standard
ZZT86 (04-20-2016)
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
car cover recommendation? lionbacker54 Cosmetic Modification (Interior/Exterior/Lighting) 34 12-10-2015 11:32 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Recommendation for GTA PDR? 1Cor10:23 CANADA 12 11-08-2014 09:08 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
